Irrigation caddy
Tue Nov 28, 2017 6:48 pm
farberm offline
Re: Irrigation caddy
Things are working fine. I have the setup connected to a water meter for the pool instead of the irrigation and it sends me a daily update of water usage.
Sat Mar 02, 2019 8:46 am
farberm offline
i seem to get this error pretty consistently.
Irrigation Caddy Error Error getting Irrigation Caddy (IrrigationCaddy) status (Irrigation Caddy isn't running): <urlopen error [Errno 60] Operation timed out>
Any idea why this would be happening frequently?
Does the plugin need updating?
The system is running and I can access it via its network ip address.
Mon Mar 04, 2019 3:10 pm
Note that I know absolutely nothing about this plugin, so this is pure speculation just based on the one error you've shared. The error indicates that the plugin is getting a network timeout issue when trying to talk to something. If it's not working ever, that might indicate that the IP of whatever it's trying to talk to has changed. If it works sometimes but other times it doesn't, that indicates that perhaps either your Mac or the thing the plugin is trying to talk to is periodically falling off the network.
