GE Caddx NX-8E
Tue Apr 07, 2020 3:44 pm
Re: GE Caddx NX-8E
I use a serial card to connect the NX to MAC:
Screen Shot 2020-04-07 at 16.43.13.png (191.52 KiB) Viewed 169 times
Tue Apr 07, 2020 4:00 pm
farberm offline
Re: GE Caddx NX-8E
I think you mentioned that you have a NX-*v2 board. That does not have RS232 built into it. I have an NX-8E that has RS-232 already on the main board.
I assume that I can run a Serial cable from the board to a global cache unit (Flex link Serial cable) to get this into my network ). My mac is not close to the security system.
I was just checking on the prior post to see if this was an alternative option to get the signal into the network.
I assume I would choose network socket...
socket://192.168.x.x:port). --- what would the port be for global cache 4999
BaudRate: 9600?
Any other settings I will need once I have it installed in a few weeks.
Did you have to do any programming on the Networx system in terms of locations/zones etc to enable communication properly?
Tue Apr 07, 2020 5:44 pm
farberm offline
Re: GE Caddx NX-8E
I would appreciate any input from prior installers. Here is what I found for programming the 8E serial port on the Caddx *E system
SERIAL PORT COMMUNICATION
Loc'n Loc'n Description Value Interpretation of Value
207 Serial Port Enable. 01 Home Automation Protocol*
208 Serial Port Baud Rate. 02 9600 bps
209 Home Automation Protocol (vice printer) "1-------" ASCII mode
210(1) NX-8E Broadcasts Enable flags (NX-8E) Intf Cfg at pwr up, Zone Status, Zones Snapshot, Partition Status, Partition Snapshot
210(2) "Nx-*E automatically send System Status, Log Event Msg, Kpd Msg Rcvd
211(1) NX-584 Command Request Enable flag Interface Config, Zone Name, Zone Status, Zones Snapshot, Partition Status, Partitions Snapshot
211(2). Sys Status, Log Event, Kpd Txt, Kpd Term Mode
211(3). Pgm Data Rqst, Pgm Data Cmd, User Info Rqst w/PIN,Set Usr Code w/PIN, Set User Auth Cmd w/PIN
211(4) Stor Comm Event Cmd, Set Clk/Calendar, Primary Kpd Func w/PIN, Prim Kpd Func wo/PIN, Sec Dpd Func, ZoneBypass Toggle
I found 3 different options but think these are close
207 1. On
208 2 9600
209 SHOULD BE BINARY -------- all off
Location.
210 (1). -2–5678
210 (2). 1234----
211 (1) -2-45678
211 (2) 12345—
211 (3) 123-5-7-
211 (4) --345678
Not sure these are correct but anyone else with an 8E board please let me know.
Tue Apr 07, 2020 8:07 pm
Re: GE Caddx NX-8E
here my config with serial ---> usb port
model NX-8v2
Screen Shot 2020-04-07 at 21.06.27.png (55.83 KiB) Viewed 135 times
Tue Apr 07, 2020 8:12 pm
farberm offline
Re: GE Caddx NX-8E
Thanks Karl. Do you remember what you programmed your NC-583 location 3 and 4 to be. They correspond to location 210 and 211 for the 8e board. Not sure I need to turn all of them on. I looked in the user info for the plugin and it just gives minimal info
Wed Apr 08, 2020 11:15 am
GE Caddx NX-8E
Sorry no. Have not touched it for 2? Years
