Device Timer Plugin
GlennNZ
Device Timer Plugin
Post by GlennNZ »
Device Timer Plugin
https://www.indigodomo.com/pluginstore/302/
https://github.com/ghawken/Device_Timer_Plugin
Device Timer tracks how long a selected Indigo device has been ON across multiple rolling windows, and also provides day-based totals and counts of ON-events. It exposes both numeric minute totals and human-friendly text strings for easy use in Control Pages and triggers.
What it does
- Tracks ON time for a target device across rolling windows (24h → 3 weeks).
- Tracks ON time for Today (midnight → now) and Yesterday (previous midnight → midnight).
- Counts OFF→ON transitions for Today and Yesterday.
- Publishes human-friendly text for all windows and day totals (for Control Pages).
- Persists displayed values across plugin restarts by reading current device states at startup and continuing from there.
- Logs midnight rollovers with yesterday’s final totals and counts.
Features
- Rolling windows: 24h, 48h, 72h, 96h, 5d, 6d, 1w, 2w, 3w
- Day totals: Today and Yesterday
- ON-event counts: Today and Yesterday
- Text variants for all time windows and day totals
- 15 second refresh cadence
- Prunes history older than the longest window (3 weeks)
Installation
1. Download or clone this plugin repository.
2. Double-click the devicetimer.indigoPlugin bundle to install
3. Enable the plugin in Indigo.
Creating a Device Timer
1. In Indigo, create a new device.
2. Type: Device Timer (custom device from this plugin).
3. Configure:
- Device to track: choose the target device whose ON time you want to measure.
4. Save the device.
The device’s default display state is timeon_today_text (readable “X hours and Y mins”).
States exposed
All numeric time values are reported in minutes with 1 decimal place.
- Rolling ON time (minutes, numeric):
  - timeon_24hours
  - timeon_48hours
  - timeon_72hours
  - timeon_96hours
  - timeon_5days
  - timeon_6days
  - timeon_1week
  - timeon_2weeks
  - timeon_3weeks
- Rolling ON time (text, human-friendly):
  - timeon_24hours_text
  - timeon_48hours_text
  - timeon_72hours_text
  - timeon_96hours_text
  - timeon_5days_text
  - timeon_6days_text
  - timeon_1week_text
  - timeon_2weeks_text
  - timeon_3weeks_text
- Day-bounded ON time (minutes, numeric):
  - timeon_today
  - timeon_yesterday
- Day-bounded ON time (text, human-friendly):
  - timeon_today_text
  - timeon_yesterday_text
- ON-event counts (OFF→ON transitions):
  - oncount_today
  - oncount_yesterday
- Target metadata:
  - target_device_id
  - target_device_name
  - target_on_state
Tip: Use the “Control Page Label” names from Devices.xml to drop these onto Control Pages, or use the text variants directly.
How values are calculated
- The plugin maintains ON/OFF intervals in memory and recomputes totals every 15 seconds.
- Rolling windows sum overlap with [now - window, now] and are reported in minutes (1 decimal place).
- Today = overlap with [local midnight today, now].
- Yesterday = overlap with [local midnight yesterday, local midnight today].
- ON-event counts increment when the target device transitions from OFF to ON.
Retention:
- Old intervals are pruned beyond the longest window (3 weeks) to bound memory use.
Midnight rollover and restart behavior
Midnight rollover:
- At local midnight:
- The plugin logs a summary line for each timer with yesterday’s final totals and ON-event counts.
- Yesterday is “locked” to that final value for the new day so it remains constant until the next midnight.
- Today resets to 0.0 minutes and 0 ON events (and begins accumulating again).
Restart:
- On startup, the plugin reads the current device states for:
- Rolling windows (timeon_* windows)
- Day totals (timeon_today, timeon_yesterday)
- ON-event counts (oncount_today, oncount_yesterday)
- It uses those as baselines and continues accumulating from there so values do not visibly reset after a restart.
- Notes:
- Rolling windows will continue from their displayed values. Because the plugin can’t reconstruct pre-restart interval edges, decay for rolling windows across a restart won’t resume until new time accumulates (this is expected and keeps the display stable).
- Today/Yesterday and their counts continue from the current device states read on startup.
Using in Control Pages and Triggers
- Control Pages:
- Use the “text” states (e.g., timeon_today_text or timeon_24hours_text) for a readable “X hours and Y mins” format.
- Use the numeric minute states for graphs or numeric displays with formatting.
- Triggers and Conditions:
- Create “Device State Changed” triggers on any of the states above.
- Example: Notify if timeon_24hours exceeds a threshold (minutes) or if oncount_today reaches a certain number.
Logging
- Plugin menu: Preferences allow setting Event Log and File Log levels and toggling debug.
- Midnight rollover logging:
- One summary line per timer showing final Yesterday minutes and ON-event count.
- The plugin also updates target metadata and interval openings at debug level.
Known limitations
- Rolling-window accuracy across restarts:
- Windows continue from the last displayed value; decay (roll-off) across a restart only resumes as new time accumulates since interval edges aren’t persisted.
- Day totals and counts persist by reading current device state values at startup. If external edits to those states occur, the plugin will treat them as the new baseline.
durosity
Re: Device Timer Plugin
Post by durosity »
Very cool! I've already got some ideas on uses for this!
matt (support)
Post by matt (support) »
Great plugin – thanks for contributing!
Return to “Device Timer”
