Added a new hub
Colly
Added a new hub
Post by Colly »
Hi Alan,
I had to replace my Neo hub as the previous one failed on me. New one is up and running and configured via the Heatmiser App with all stats working. I'm not able to connect it to Indigo however. See below from the log, I've updated the network address. Any suggestions?
   Starting plugin "Heatmiser-Neo 2022.1.2" (pid 17228)
   Started plugin "Heatmiser-Neo 2022.1.2"
   Heatmiser-Neo                   Starting Heatmiser Neo plugin
   Heatmiser-Neo                   Neo comms logging is on
   Heatmiser-Neo Error             Cannot detect devices
   Heatmiser-Neo                   Neo time will be synchronised daily with Indigo
   Heatmiser-Neo                   Starting Heatmiser Neo monitoring thread
   Heatmiser-Neo Error             getNeoData: Socket connect error
Thanks in advance.
Colly
Colly
Re: Added a new hub
Post by Colly »
Problem now resolved after reading a separate topic which recommended changing an App API setting.
racarter
Re: Added a new hub
Post by racarter »
Sorry Colly, I’ve been away for a few days. Glad you managed to sort it. :)
Colly
Re: Added a new hub
Post by Colly »
Might get back to you yet as I think there may be some issues still. The communication channel is open at least.
Will be this evening before I get back home to review.
Colly
Re: Added a new hub
Post by Colly »
Alan,
I think what has happened with the new hub is that the stats have been assigned new nodes and they don't match to what the previous ones were. The strange behaviour I was seeing was some rooms mysteriously heating and others that didn't match in Indigo.
So how do I update the names? Ideally to match/resync with the previous Indigo stats so all my schedules work.
racarter
Re: Added a new hub
Post by racarter »
I suggest you stop the plugin then rename all your existing Indigo devices. Then restart the plugin and let it create new devices. After that you can transfer dependencies from the old devices to the new, then when you’re happy they’re working, delete the old devices.
Colly
Re: Added a new hub
Post by Colly »
I’ll give that a go, sounds like a plan.
Colly
Re: Added a new hub
Post by Colly »
Tried it with one device but no dice..
Getting below in the log.
   Reloading plugin "Heatmiser-Neo 2022.1.2" using API v3.0
   Stopping plugin "Heatmiser-Neo 2022.1.2" (pid 59699)
   Heatmiser-Neo                   Stopping Heatmiser Neo plugin
   Stopped plugin "Heatmiser-Neo 2022.1.2"
   Starting plugin "Heatmiser-Neo 2022.1.2" (pid 61003)
   Heatmiser-Neo                   Neo comms logging is off
   Heatmiser-Neo Error             Cannot update ENGINEERS_DATA.  Will try again tomorrow.
   Heatmiser-Neo                   Update failed at step 'Get ROC'
racarter
Re: Added a new hub
Post by racarter »
Turn on comms logging. Might provide a clue.
Colly
Re: Added a new hub
Post by Colly »
Log output below after a plugin restart.
   Z-Wave                          received "Office - Motion Sensor" status update is off
   Stopping plugin "Heatmiser-Neo 2022.1.2" (pid 61312)
   Starting plugin "Heatmiser-Neo 2022.1.2" (pid 68492)
   Heatmiser-Neo                   --> b'{"INFO":0}'
   Heatmiser-Neo                   <-- b'{"devices":[{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"18.7","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"5 days 18:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":13,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Landing"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"17.3","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"19.0","MIN_TEMPERATURE":"17.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"5 days 20:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":28,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Master"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"17.0","CURRENT_TEMPERATURE":"18.1","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":20,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Master Ensuite"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"16.0","CURRENT_TEMPERATURE":"18.0","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":36,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Office"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"17.7","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"16.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"5 days 18:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":18,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Katies Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"17.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"16.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"5 days 18:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":28,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Ryans Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"17.0","CURRENT_TEMPERATURE":"18.4","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"19.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":21,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Kids Shower"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"11.5","CURRENT_TEMPERATURE":"11.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"12.0","MIN_TEMPERATURE":"12.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":36,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Games Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"20.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":20,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"6 days 03:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":41,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Living Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"20.9","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"20.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"6 days 03:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":14,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Kitchen"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"20.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"6 days 03:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":16,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Dining Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"16.0","CURRENT_TEMPERATURE":"19.8","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"5 days 16:00","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":9,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Back Toilet"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"16.0","CURRENT_TEMPERATURE":"19.7","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"6 days 04:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":27,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Entrance"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"20.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"6 days 03:30","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":14,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Sitting Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"16.0","CURRENT_TEMPERATURE":"17.6","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"18.0","MIN_TEMPERATURE":"17.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":15,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Guest Ensuite"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"16.0","CURRENT_TEMPERATURE":"16.9","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"17.0","MIN_TEMPERATURE":"16.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":108,"WRITE_COUNT":20,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Guest Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"0.0","CURRENT_TEMPERATURE":"255.255","DEMAND":false,"DEVICE_TYPE":6,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":0,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"255.255","MIN_TEMPERATURE":"255.255","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"7DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"TIMECLOCK":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":true,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":81,"WRITE_COUNT":12,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Heatmiser Socket"}]}\n'
   Heatmiser-Neo                   --> b'{"NTP_OFF":0}'
   Heatmiser-Neo                   <-- b'{"result":"ntp client stopped"}'
   Heatmiser-Neo                   --> b'{"DST_OFF":0}'
   Heatmiser-Neo                   <-- b'{"result":"dst off"}'
   Heatmiser-Neo                   --> b'{"READ_DCB":100}'
   Heatmiser-Neo                   <-- b'{"AIR_ALT_DELAY":60,"AIR_ALT_DELAY_END":6,"AIR_ALT_DELAY_START":23,"AWAY":false,"BOOTTIME":1699321830,"COOLBOX":"heating","COOLBOX_PRESENT":0,"CORF":"C","DATE":"Nov 10","DEVICE_ID":"NeoHub","DSTAUTO":false,"DSTON":false,"EXTENDED_HISTORY":"off","Firmware version":2199,"GDEVLIST":[2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,1,17],"GLOBAL_SYSTEM_TYPE":"HeatOnly","HEATING_LEVELS":4,"Homekit":true,"LAST_RECONNECT":25,"LAST_RECONNECT_TIME":1699321855,"LEGACY_LOCAL_PORT":true,"LEGACY_LOCAL_PORT_FORCED":true,"NO_RF_BROADCAST":false,"NTP":"Stopped","PARTITION COUNT":"4","PROGFORMAT":4,"RF_ID":51,"SET_GLOBAL_HC_MODE":"heating","TIME":"10:31:58","TIMEZONE":0,"TIMEZONESTR":"","UPTIME":290488,"ZIGBEE_CHANNEL":"20"}\n'
   Heatmiser-Neo                   --> b'{"ENGINEERS_DATA":0}'
   Heatmiser-Neo                   <-- b'{"Back Toilet":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Dining Room":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Entrance":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":27,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Games Room":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Guest Ensuite":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":27,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Guest Room":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":27,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Heatmiser Socket":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":27,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":0,"FROST TEMPERATURE":0,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":0,"SWITCHING DIFFERENTIAL":0,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Katies Room":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Kids Shower":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Kitchen":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Landing":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Living Room":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Master":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Master Ensuite":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Office":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Ryans Room":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":26,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0},"Sitting Room":{"COOLING DEAD BAND":0,"CURRENT DAY":5,"CURRENT TIME HOURS":10,"CURRENT TIME MINUTES":27,"FAIL SAFE ENABLED":0,"FAN SPEED":0,"FLOOR LIMIT TEMPERATURE":28,"FROST TEMPERATURE":12,"MAX PREHEAT":0,"OUTPUT DELAY":0,"PUMP_DELAY":0,"PUMP_DELAY_TIME_LEFT":"0:00","RADIATORS OR UNDERFLOOR":0,"RATE OF CHANGE":20,"SWITCHING DIFFERENTIAL":1,"SWITCH_DELAY":0,"SWITCH_DELAY_TIME_LEFT":"0:00","TARGET DEVICE BOARD":0,"TARGET ZONE":0,"USER LIMIT  (UP/DOWN LIMIT )":0}}\n'
racarter
Re: Added a new hub
Post by racarter »
Hi Colly
DM me your email address and I'll send you an update with additional debug code.
Colly
Re: Added a new hub
Post by Colly »
Thanks Alan for your efforts this evening in resolving my issues. Much appreciated.
Return to “Heatmiser Neo”
