Error logging into MyQ server
madscientist
Post by madscientist »
Is anybody else having trouble logging into the MyQ server? I haven't changed anything on my end, but all of sudden I'm getting these errors in the Indigo log:
Error logging into MyQ server: Error requesting data from https://partner-identity.myq-cloud.com/ ... /authorize: Cannot connect to host partner-identity.myq-cloud.com:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:997)')]
Is this just Chamberlain messing with their API again?
DaveL17
Re: Error logging into MyQ server
Post by DaveL17 »
I searched today's log for "MyQ" and came up with nothing.
My Plugins and Scripts
madscientist
DaveL17 wrote:I searched today's log for "MyQ" and came up with nothing.
Are your MyQ devices accessible within Indigo?
DaveL17
Post by DaveL17 »
madscientist wrote:Are your MyQ devices accessible within Indigo?
Yes. I just opened my garage door with the Indigo Touch app.
GlennNZ
Post by GlennNZ »
Looks surprisingly similar to a error that I have seen recently with a API upgrade. Down to the line number
[It is normally because of failure of verification of cerificates at API level. Typically can be fixed by adding verify=False, to the requests code line. (presuming requests is used)
eg. response = request.post(url, verify=False, allow_redirects=False) etc.etc.
Not quite sure why one might see it and not another, but may have something to do with OSX versions and SSL versions….
Here though a pymyq library is used - so above likely not that helpful…]
Or alternatively - may be because their has been some API changes…
Glenn
madscientist
Strangely enough the errors have stopped without my intervention. Must have been on the Chamberlain end of things.
Locked
Return to “MyQ”
