iOS 16.2 HomeKit "Architecture" Changes
7rdr7
Post by 7rdr7 »
Apparently HomeKit has a new "architecture" in iOS 16.2. Do you think this will have any issues with HomeKitLink?
GlennNZ
Post by GlennNZ »
Eek! Who knows with Apple I suspect is the bottom line.
The only good news is every implementation will have the same potential issue (if indeed there is one)
This homebridge thread - probably will be most updated
https://github.com/homebridge/homebridge/issues/3250
& this feedback there reassuring
I have convert my Home to new architecture 16.2 also updated HomePod mini , iPad and iPhone to 16.2 and all working as before. Homebridge is not affected and working OK.
Seems like should be okay - but wouldn’t race in to update!
7rdr7
Re: iOS 16.2 HomeKit "Architecture" Changes
Post by 7rdr7 »
Promising link. Thanks!
racarter
Post by racarter »
Since the change, every 2-3 days all my Indigo devices stop responding in Home, and the only way I've found to fix things is to delete the HomeKitLink accessory in Home then re-add it and all the devices, which is an absolute pain!
Anyone else seeing this issue?
GlennNZ
Post by GlennNZ »
What change?
racarter
Post by racarter »
The change to HomeKit architecture in 16.2
GlennNZ
Post by GlennNZ »
So you have upgraded to Beta 16.2 and force updated all your homekit hubs?
racarter
Post by racarter »
Yes
GlennNZ
Post by GlennNZ »
I would be surprised if anyone else has forced upgraded all hubs to a beta implementation of Homekit. (It also means ipad’s can no longer be Hubs, amongst one of many changes)
See here:
https://www.homekithelper.net/tips/ios- ... chitecture
Certainly I haven’t, and based on the hub communication changes I’m somewhat surprised it actually works without problem…. (2 days dying aside - obviously!)
I’ll have a look and see if any reports. (is a OS16 unpairing issue….)
racarter
Post by racarter »
I only use HomeKit for a few Siri things so it's not a huge deal - hence the decision to try it!
GlennNZ
Post by GlennNZ »
Brave! I looked at it - but the fact it seems to push the beta to every device making it irreversible seemed a bit risky!
I’ll update the libraries pairing code issue now - give me 5 (maybe 10 development machine is off…) minutes - and then update plugin to 0.4.3 code…
GlennNZ
Post by GlennNZ »
(9 minutes! Close.)
Go to
http://www.github.com/Ghawken/HomeKitLink-Siri
Click Code button and update to 0.4.3
Seems this change may fix your earlier adopter issue! Let us know and will push update.
racarter
Post by racarter »
Lightning fast!
I've installed, deleted and re-paired. Everything looks good so far.
I'll keep you posted over the next few days!
Many thanks Glenn. :)
GlennNZ
Post by GlennNZ »
Fast, but missed a bit - update to 0.4.4 - should more robustly help I think.
Glenn
racarter
Post by racarter »
Thanks Glenn - installed OK. :)
Return to “HomeKitLink Siri”
