HUE Start dimming command results in error
PeteVis
Post by PeteVis »
I just upgraded to the latest official release 1.8.7, and now when I have a trigger that uses the 'start dimming' command, the following error is displayed in the error log :
Hue Lights Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 337, in runConcurrentThread
AttributeError: 'DimmerDevice' object has no attribute 'pluginpros'
   Hue Lights Error                plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Is this command not supported anymore ?
Re: HUE Start dimming command results in error
Will be fixed today.
[EDIT] was already fixed in v 1.9.14
There is a new version 1.10.14 available now, https://github.com/IndigoDomotics/Hue-L ... g/v1.10.14
That can run under MAC OS 12.3.. AFTER indigo 2022 is released
!!! do not upgrade to MAC OS12.3 (Monterey) yet !!!!,
But this release should work fine with indigo 2021 and 2022 and older versions
PeteVis
Post by PeteVis »
Thanks Karl, but this is scaring me off.. with the bold font :shock:
Anyway, I was brave and tried the version you linked, and immediatly I see this pop up in red letters in the log :
   Hue Lights Error                Error in plugin execution ExecuteAction:
  File "plugin.py", line 2943, in actionControlDimmerRelay
  File "plugin.py", line 7750, in doOnOff
NameError: global name 'logChanges' is not defined
and also this :
  File "plugin.py", line 2952, in actionControlDimmerRelay
  File "plugin.py", line 7796, in doOnOff
I'm on Indigo 2021.1 and 10.15.7
PeteVis
Post by PeteVis »
thanks for the quick fix :D
jay (support)
Post by jay (support) »
NOTE: Indigo 2022.1 has solved the compatibility issue with macOS Monterey 12.3+.
Locked
Return to “Archives”
