No ibeacons detected
smarthome01
Post by smarthome01 »
I've installed the piBeacon plugin and configured the rpi according the help docs. The rpi device is 'up' in the device list, but no ibeacon ist created although I have placed a Minew Beacon close to the rpi. The Minew beacon is listed in the output of hcitool lescan command.
I've doublechecked the config, but can't find anything wrong (for me).
Environment:
Indigo 2021.1 running on miniMac, OS Big Sur 11.5.2
piBeacon Plugin: latest version 7.138.542
Rpi: raspberry zero (can this be the problem?) connected via WLAN with Indigo server
Any help is appreciated,
Reinhold
Can you ssh to the rpi?
Then
cd pibeacon
cat parameters
Post the Output.
You can mask the password
And in plugin config enable all debug
Then post pibeacon.log file in the indigo logs directory under xxxx/…pibeacon
And in menu do a print config.
smarthome01
Re: No ibeacons detected
I have collected the requested files and merged them together in one file. I do hope youn find all necessary information, otherwise I'll produce more logs, thanks a lot so far,
Reinhold
rpi-logs.txt
rpi-logs includes parameter and iBeacon.log
(11.44 KiB) Downloaded 152 times
Ok
Could you do
Ssh to rpi
cd pibeacon
Is - l
Then
ps -ef | grep .py
Then
tail -f /var/log/pibeacon
And email to
Karlwachs at me com
Return to “piBeacon”
