Scene Switch ZME_WallC-S
Sun Jul 19, 2020 2:47 pm
Bildhauer offline
Has anyone an example (with screenshots)= how to get it run?
The details of a. m. wall switch is:
Indigo Z-Wave Version: 7.4.1
Node ID: 164
Model: Remote Double Switch (ZME-WALLC-S)
Model ID: 01000101
Manufacturer: Duwi
Manufacturer ID: 0115
Protocol Version: 3.92
Application Version: 1.01
Model Definition Version: 1
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 8Ev1 8Fv1 98v1 59v1 5Av1 5Bv1 5Ev1 20v1 2Dv1 70v1 72v1 73v1
Encryption Status: Enabled for Commands 8F
Features: routing, battery, beaming, security, waking
Neighbors: 5, 6, 9, 10, 11, 39, 40, 51, 52, 53, 80, 99, 101, 103, 137
Associations: 1:[1] 2:[1] 3:[1] 4:[1] 5:[1]
Config Values: 1:1 2:1 11:8 12:8 13:8 14:8 21:1 22:0 24:1 30:1
I've tried to get it run with "Z-Wave Scene Controller" v1.40 but without success.
This is what I see in the logs but how to get actions on it?
Z-Wave received "Taster Büro" scene 1 (0001)
Z-Wave received "Taster Büro" scene 5 (0005)
Would be niche to receive some example of guys who are running these switches!
Mon Jul 27, 2020 2:16 am
Re: Scene Switch ZME_WallC-S
Did you get anywhere with this?
I’ll look when I get to my desk.
Peter
Mon Jul 27, 2020 2:27 am
mclass offline
I have had one of these in service for some time with only average success.
I use it by having triggers that detect those zwave scene messages you’re seeing in the log. But it hasn’t proved to be very reliable :-(
mclass
Mon Jul 27, 2020 2:29 am
We need to dig into the Zwave values if it’s not reliable, see what it’s actually sending.
Put a Zwave Watcher (plugin) on it, so we can monitor just that device without filling the logs.
Peter
Mon Jul 27, 2020 5:16 pm
If you create a new Trigger in Indigo and choose Z-Wave Command Received as the Type and Incoming Command Received from Device as the Event, then choose Taster Büro on the From popup control, what options do you then see in the Received popup? If Basic Button 1 Pressed is an option, then select it and see if that action for the Trigger executes and copy/paste the Event Log results.
Thu Nov 12, 2020 6:56 am
Bildhauer offline
Still seeing this:
Z-Wave Indigo Device "Taster Büro" Z-Wave Properties:
Node ID: 179
Model ID: 01000101
Manufacturer: Duwi
Library Type: 3
Neighbors: - none -
Config Values: 1:1 2:1 21:1 22:0 24:0 30:1 11:8 12:8 13:8 14:8
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 65.36 W
Z-Wave received "Zwischenstecker Switch" power load to 44.71 W
Z-Wave Error device "Taster Büro" may be asleep. configuration changes will be set during the next wake interval.
Can't geit it run. Any clue what I can do. Attached screenshots of my settings.
Remote Desktop Bild 12. November 2020 um 13.52.05 MEZ.jpg (309.86 KiB) Viewed 889 times
Thu Nov 12, 2020 4:22 pm
It looks like Peter is helping you over on his plugin forum here.
But I'm curious what you see when you create a Trigger as I described in my previous post above? The screen shots you included are for the Device Settings dialog, not the Trigger dialog (using type Z-Wave Command Received). See my previous post above.
