Can't "Comm Enable" a ZWave Device
Mon Mar 23, 2020 8:39 pm
aldera offline
Hello,
I have a GE light switch that has been working well for years. In fact, I've never had a zwave device go bad in over 9 years. However, this particular switch has stopped working as a zwave device. I can physically turn it on/off at the switch itself. I've tried the following:
1. Removed and reset power to the switch.
2. Reloaded the ZWave Interface (Interfaces>>ZWave>>Reload).
3. Shutdown the server and restarted it.
4. Enable Indigo Communications - I can check/uncheck the checkbox on the "Edit Devices" screen (second graphic) I can't enable the "Comm Enabled" checkbox on the main Indigo screen. The device itself is grayed out on the main screen.
5. Tried to resync the device via the "Sync" screen. The "Sync using node" dropdown box is grayed out. (see first graphic)
I haven't tried excluding and including it. I don't want to redo all the triggers and control display pages if I can avoid it.
Are there any other things I could try first? Thank you for any input!
Sync Device "window"
Edit Device "window"
Tue Mar 24, 2020 9:25 am
Re: Can't "Comm Enable" a ZWave Device
The selector being grayed out means that the node at ID 36 is no longer in the Z-Stick. Did you exclude it without re-including it?
Tue Mar 24, 2020 11:03 am
Excluding / including isn’t an issue - you don’t lose triggers etc.
Those are tied to the ‘device’ in Indigo, not to the node or physical instance.
Use Zwave > start inclusion and include it again so it gets a new node ID. Then edit your device as per the screenshot and pick the new node id instead of the missing node.
Tue Mar 24, 2020 1:53 pm
aldera offline
I never excluded it. However, I was trying to exclude another device. I don't know how the switch ended up getting excluded unless the wife happened to hit the light switch at the same time that I was trying to exclude the other device. Very weird.
Tue Mar 24, 2020 1:55 pm
aldera offline
Thanks for the response. I did end up including it again and setting the new node to my old triggers and control pages. Thank again.
Ralph
