JSON error from controller
Thu Feb 13, 2020 10:09 am
stewkenly offline
Hi, I have the uniFi controller running on the same mac as indigo and tell the plugin to connect to the controller. I keep seeing these error messages.
Starting plugin "uniFiAP 7.27.169" (pid 77825)
uniFiAP initializing ...
uniFiAP path To files: =================
uniFiAP indigo /Library/Application Support/Perceptive Automation/
uniFiAP installFolder /Library/Application Support/Perceptive Automation/Indigo 7.4/
uniFiAP plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
uniFiAP Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/
uniFiAP Warning logger enabled for WARNING ==> TEST ONLY
uniFiAP Error logger enabled for ERROR ==> TEST ONLY
uniFiAP Critical Error logger enabled for CRITICAL ==> TEST ONLY
uniFiAP check /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log <<<< for detailed logging
uniFiAP Plugin short Name UniFi
uniFiAP my PID 77825
uniFiAP set params for indigo V 7.4
Started plugin "uniFiAP 7.27.169"
uniFiAP testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
uniFiAP myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log; debugLevel= []
uniFiAP Error UNIFI executeCMDOnController has error, no json object returned: ('', ' % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\n')
uniFiAP start runConcurrentThread, initializing loop settings and threads ..
uniFiAP Error UNIFI executeCMDOnController has error, no json object returned: ('', ' % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r100 30 0 0 100 30 0 2008 --:--:-- --:--:-- --:--:-- 2142\n')
uniFiAP initialized ... looping
Is there something special that needs to be configured on the controller side I am missing?
Thu Feb 13, 2020 10:55 am
kw123 online
Re: JSON error from controller
the connection seems not to work.
do you have any security ON on your mac, userid/ password correct , ip number correct .. sorry to ask these questions, but those are my most common mistakes.
could you send me your sendup .. config etc.. !! there are userid and passwords in there !!
karlwachs me com
