path error?
Fri Jan 24, 2020 2:06 pm
whmoorejr offline
path error?
Hopefully a quick fix....
The plugin is looking for the image file in the wrong location (wrong URL, wrong port)
 Image Downloader and SecuritySpy Helper Error    error fetching image. error: HTTPConnectionPool(host='127.0.0.1', port=8007): Max retries exceeded with url: /++image?cameraNum=2 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x110a2c990>: Failed to establish a new connection: [Errno 61] Connection refused',))
Actual Location for that image is
http://192.168.1.10:8000/++image?cameraNum=2
I'm not sure where it's getting the 127 address from so I can change it to my 192 address.
Bill
Fri Jan 24, 2020 3:05 pm
Re: path error?
127.0.0.1 is the local machine. So it's assuming it's running on the same system as Indigo.
Is 192.168.1.10 the IP address of the Indigo machine, or is SS running on a different machine?
Fri Jan 24, 2020 4:17 pm
vtmikel offline
Re: path error?
Go to Plugins -> Image Downloader and SecuritySpy Helper -> Configure
Change the IP to the IP of your securitySpy server. it doesn't have to be 127.0.0.1 (localhost).
Fri Jan 24, 2020 6:28 pm
whmoorejr offline
Re: path error?
:oops:
I don't know how I missed that. Thanks much.
Bill
