uniFi plugin setup help!
Tue Jan 07, 2020 11:14 am
bbbullock offline
I am relatively new to the uniFi network environment and am now trying to install the uniFi-WiFi-AP plugin in indigo. My objective in connecting Indigo w/ my uniFi environment is for presence detection.
Something must be wrong in my plugin config, because I cannot get beyond a set of errors. Below is the log file that I'm currently seeing in Indigo. What might I be doing wrong?
------Log-----------
Starting plugin "uniFiAP 7.26.169" (pid 1443)
uniFiAP initializing ...
uniFiAP path To files: =================
uniFiAP indigo /Library/Application Support/Perceptive Automation/
uniFiAP installFolder /Library/Application Support/Perceptive Automation/Indigo 7.4/
uniFiAP plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
uniFiAP Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/
uniFiAP Warning logger enabled for WARNING ==> TEST ONLY
uniFiAP Error logger enabled for ERROR ==> TEST ONLY
uniFiAP Critical Error logger enabled for CRITICAL ==> TEST ONLY
uniFiAP check /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log <<<< for detailed logging
uniFiAP Plugin short Name UniFi
uniFiAP my PID 1443
uniFiAP set params for indigo V 7.4
Started plugin "uniFiAP 7.26.169"
uniFiAP testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
uniFiAP myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log; debugLevel= []
uniFiAP start runConcurrentThread, initializing loop settings and threads ..
uniFiAP Error UNIFI executeCMDOnController error: (wrong UID/passwd, ip number?) ...>>{"meta":{"rc":"error","msg":"api.err.Invalid"},"data":[]}<<
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 104 100 57 100 47 70 58 --:--:-- --:--:-- --:--:-- 128
Connection
100 104 100 57 100 47 71 59 --:--:-- --:--:-- --:--:-- 130
Connection
uniFiAP initialized ... looping
uniFiAP Error getMessages: (1) error connecting to ip#: 192.168.1.15 wrong ip/ password or system down or ssh timed out or ..?
uniFiAP Error getMessages: (1) error connecting to ip#: 192.168.1.16 wrong ip/ password or system down or ssh timed out or ..?
uniFiAP Error getMessages: (1) error connecting to ip#: 192.168.1.76 wrong ip/ password or system down or ssh timed out or ..?
Jan 7, 2020 at 11:04:39 AM
100 104 100 57 100 47 67 55 --:--:-- --:--:-- --:--:-- 122
Connection
Jan 7, 2020 at 11:05:05 AM
Jan 7, 2020 at 11:05:31 AM
Jan 7, 2020 at 11:05:56 AM
Jan 7, 2020 at 11:06:22 AM
Tue Jan 07, 2020 11:34 am
kw123 online
Dumb question:
Are the userid... ip numbers correct?
And check the plugin.log file
Tue Jan 07, 2020 2:23 pm
Re: uniFi plugin setup help!
The "duh" moment for me when I had similar errors is that the plugin needs to point at the *device running the controller software* not the actual Unifi hardware's IP address.
Also the controller software must be running on the device.
Tue Jan 07, 2020 3:12 pm
kw123 online
Well, actually all
Of them.
It connects to the controller and the switches and access points and gateway
Tue Jan 07, 2020 3:45 pm
bbbullock offline
Ok...so I got many (most?) of the errors eliminated. There was an issue with login credentials for the UniFi Controller...now corrected.
I'm still though getting this error in the Indigo Event Log:
Jan 7, 2020 at 3:36:25 PM
100 47 0 0 100 47 0 225 --:--:-- --:--:-- --:--:-- 224
100 104 100 57 100 47 64 52 --:--:-- --:--:-- --:--:-- 116
I'm not clear on what UID/Passwd, ip number it might be referring to? Does "Controller" = "Cloud Key"? Or does Controller refer to the USG? I've tried the credentials for both, but no success.
Tue Jan 07, 2020 4:06 pm
kw123 online
The controller connection seems to have some issues. You only need that for reports and auto discovery. You can switch if off. All client info is coming from the switches and ap
The controller is the box where you login with chrome to see the UniFi info
Either software install on mac or the UniFi stick
Tue Jan 07, 2020 6:04 pm
kw123 online
just for completeness: here my config
Screen Shot 2020-01-07 at 17.49.57.png (192.85 KiB) Viewed 199 times
Screen Shot 2020-01-07 at 17.50.16.png (154.31 KiB) Viewed 199 times
the controller is the software that collects the info from all unifi devices. it can run on various systems. I had it on
MAC
raspberry
unifi cloud key v 1
unifi cloud key v 2
they all work fine
the userid / password are the same as you use to login to the web page with chrome, to set eg WiFI config etc.
normally: 192.168.x.x:8443
The plugin uses http access to the controller software to query the DB for
1. new devices
2. reports
== details for each Unifi device and details for clients
== reports for controller access, logs/ warnings, web traffic ...
the controller part is not required for 90% of the plugin functionality, all normal client functions (presences, wifi info ..., dhcp) is gathered directly from the unify devices
- gateway
- switches
- APs
