Homekit camera frame update rate
Sat Jan 04, 2020 9:36 pm
akimball offline
Hi, I apologize if this question has been answered (i looked) but i’m using HKB with cynical securityspy plugin and have successful camera output in homekit... if you call 1 frame every 10-seconds successful. In fact, I have 3 cams now doing their 1-frame every 10-seconds thing ...each. At that rate a garden snail could theoretically slime it’s way across my entire front porch and never be noticed by the cameras.
Is there any way to do better than 1 frame per 10 seconds? This appears to be a homekit limitation but I can’t tell.
TIA
-Al
Sun Jan 05, 2020 9:08 am
cuhouse offline
Re: Homekit camera frame update rate
TIA
I am running 2 cameras and see the same thing as you describe. I assumed this was the way it is supposed to work. Basically like a snapshot and if you need to see more detail on a particular camera, you select it and you get a nice live shot.
Jody
Indigo 7.4, Catalina , Dedicated late 2014 Mac Mini, PowerLinc 2413U, Aeon Labs Gen 2 .
Sun Jan 05, 2020 5:18 pm
akimball offline
[/quote]
Jody[/quote]
Thanks for the response. I take it that the “nice live shot” you mention is still a single frame (that’s what I get too).
It would be acceptable if I could get a frame every second or two minimum, but 10 seconds is just too long. I’ll keep googling for a solution. I’m wondering if the dlink or logitec cams made for homekit have this limitation. I’ll start my research there.
It’s not a huge problem if this can’t be improved since security spy itself is about 2 clicks away as is my skybell doorbell camera.
-al
-Al
Sun Jan 05, 2020 8:16 pm
cuhouse offline
Jody[/quote]
-al[/quote]
By “nice live shot” I mean it is a live view of the scene the camera is viewing. The cameras time stamp is ticking off each second. The small picture is every 10 seconds as you state but when I select that picture by touching it, it opens to a full screen live view.
Jody
Mon Jan 06, 2020 7:55 am
jalves offline
My cameras (7, all Amcrest) have the same response. Main Home window thumbnail refreshes every 10 seconds. However, clicking on the thumbnail brings up a live image. The refresh rate seems to vary according to network traffic and connection method.
Running Indigo 7.4.1 on a 27" iMac (mid-2017), 40G memory, 1T Fusion Drive, OS X 10.15.3
Jeff
Mon Jan 06, 2020 8:39 am
akimball offline
Thanks again for the information. I checked images in homekit again and they are single frame still shots even after I click on the images expanding them. Not sure the issue I’m having. I’ll review some more this week.
-al
-Al
Mon Jan 06, 2020 2:09 pm
siclark offline
Same. Clicking on them shows orange button showing Live and I can see the seconds tick up so I'm getting at least one frame per second.
Mon Jan 06, 2020 3:08 pm
akimball offline
Haven’t been home to investigate yet, but I’m wondering if I have cynical’s securityspy plugin set up correctly.
-Al
