Using Siri to turn on a device for N minutes thru HKB
Fri Jan 03, 2020 9:02 pm
P15-D24 offline
We use HomePods to access the Indigo via HKB. Anyway to tell it to do an action for a specific period of time like turn on the porch light for 5 minutes, then shut it off?
The time period would be a variable.
Running OS X 10.15.3 on 2018 Mac Mini, Indigo 7.4.1
http://www.p15-d24.com
Fri Jan 03, 2020 10:40 pm
rehafer offline
Re: Using Siri to turn on a device for N minutes thru HKB
You could add Shortcuts to the mix. Write a Shortcut that turns on the device and sets a timer; and another that turns it off when the timer is done.
Thu Jan 09, 2020 9:28 pm
P15-D24 offline
Good call, as I hadn't looked at shortcuts at all since they were released. Only issue is it is currently only on iOS and the only device I have is an iPhone. Makes development a little difficult. I have read it is in the Catalina beta so hopefully they will have a MacOs version shortly.
