This plugin will use the python API published by Erik Eriksson: https://github.com/molobrakos/volvooncall
I haven't written it yet, other than grabbing the API, but it develops the work I did with @MortenCols on viewtopic.php?f=5&t=17661.
Current Features
- None
- None
- None
This plugin creates a number of Actions under "Volvo On Call actions". You can combine these with your own schedules, triggers and control panel buttons or simply execute them from the Indigo client.
When you install the plugin, you'll need to create a new device called Volvo On Call > Volvo Vehicle for each car you have. When you create it, you can choose which state to display in the Indigo UI - this defaults to battery_level but you can change to any existing state.
Download link - v1.0.00
NOT YET WRITTEN!
Those who have seen me around the forums will know I usually participate in the forums at least daily if not several times; however please be aware this is usually from my iPhone when I'm away from my desk. I will endeavour to support this plugin as quickly as possible, but (as with everyone) I have busy periods of the year when I'm simply not at my desk long enough to do all I'd like to, including fixing or updating plugin code, even if you see me actively responding to other threads.
Enjoy!
Peter
