Regular schedule vs holiday schedule
Tue Oct 01, 2019 7:53 pm
rgspb offline
I'm not real sure if i'm posting this in the correct forum but we'll see. I have a set of outside lights that come on at "Evening" 100%. At "Bedtime" they dim to 30% and then turn off completely later in the morning. For Halloween I'm putting some flicker flame LEDs in these fixtures. Since these bulbs aren't dimmable I want to skip the dimming at "Bedtime" and just turn them off completely. I'm just not sure what is the best way to set up a temporary schedule for these lights without completely changing my "Evening" and "Bedtime" action groups.
Wed Oct 02, 2019 9:01 am
Dual offline
Re: Regular schedule vs holiday schedule
I think you can disable your normal
Schedule on the 31st and enable it on the 1st. There should be a checkbox IIRC.
Fri Oct 04, 2019 9:59 am
rgspb offline
I think really what I'm looking to do is have a Condition attached to an item in an action group:
Turn light off if variable = Holiday
Brighten light to 30% if variable = Not Holiday
For now I'm just going to change that item in the list back and forth manually
Fri Oct 04, 2019 10:09 am
Have this script running every night at 12:01am:
# indigo.variables[1980497029] # "isHoliday"
# indigo.variables[1479852422] # "whatHoliday"
from datetime import date
import holidays
indigo.variable.updateValue(1980497029, value="False")
indigo.variable.updateValue(1479852422, value="None")
us_holidays = holidays.UnitedStates()  # or holidays.US()
if date.today() in us_holidays:
   indigo.variable.updateValue(1980497029, value="True")
   indigo.variable.updateValue(1479852422, us_holidays.get(date.today()))
That updates two Indigo variables - isHoliday (boolean) and whatHoliday (string).
Very useful.
I'm not sure if the holidays library is installed by default. You might need to use pip to install it.
