Outdoor Christmas Lights....recommendations please
Sat Dec 28, 2019 5:18 pm
siclark offline
Re: Outdoor Christmas Lights....recommendations please
noel1983 wrote:
Still pleased with them and good fun, might be my Wi-Fi tbh
Mine is losing WiFi as well. Completely going off line. Think it should do what my rPis do and auto restart if lost network connection.
Sat Dec 28, 2019 5:22 pm
siclark offline
I'm on 0.8.5 and just seen that both next pre releases have this functionality. I need to upgrade
Sun Dec 29, 2019 8:59 am
siclark offline
Pre release v0.9 looks great but doesn't appear to work on nodemcu
Sun Dec 29, 2019 12:28 pm
neilk offline
I just flashed a NodeMCU with the pre-release v0.9 and it seems to work for me (albeit it has not LED's attached), I am not going to chance an over the air update until the lights are ready to come down. It works fine with the plugin, and the new effects and palettes show up as expected. I will have a play with segment support but no promises depending on how much effort it will be, but I will also add "Output Diagnostic Data to Log" option as I am not sure how useful having WIFI strength as a device state is. Not a huge effort to do that, I just need to figure out elegantly handling different WLED versions and the associated API differences, so let me know if the approach of dumping that data on request to the log works for troubleshooting.
The Wifi strength only shows as 50% and I am about 1.5m from a Unifi AP
Neil
Sun Dec 29, 2019 12:33 pm
siclark offline
It works fine and I see the device on the iOS app but the lights don't work
Sun Dec 29, 2019 1:10 pm
Ksullivan offline
Using the 0.9 version and all working for me
Sun Dec 29, 2019 1:24 pm
neilk offline
I just posted a new version that pushes the WIFI data to the Indigo Event log if the plugin debugging toggle is enabled. This is really quick and dirty but will handle multiple WLED versions. The 0.9.0 has a number of new options in the API that are yet to be documented so I will hold fire on other changes (I am doing some other housekeeping).
https://github.com/neilkplugins/WLED-in ... .0.5-alpha
I will also add a test strip to the NodeMCU I have just flashed with 0.9.0 and let you know.
Neil
Sun Dec 29, 2019 1:28 pm
Colly offline
4 strips working fine for me, didn’t try OTA update.
Sun Dec 29, 2019 3:53 pm
siclark offline
Got 0.8.6 working to cope with lost network connection. Not sure why 9 didn't work but also couldn't add more than 1 extra segment which wad main reason for upgrading.
Sun Dec 29, 2019 4:00 pm
siclark offline
This is my squashed connection in an IP68 box and the new waterproof connection I soldered on to allow the cables to be separated.
I plan to replace the two boxes I have with one big one in the summer and get it as bit neater. Plus add another 200 bulbs on!!
Tue Dec 31, 2019 2:24 pm
Gangotti offline
Have any of you had issues with all the pixels flashing randomly? when I turn off the pixels in wled the flashing stops, but when I turn them on it starts back up. I have an appropriately sized power supply and all my pixes are showing color properly. the data signal for my pixels is coming off d4 on the nodemcu. any thoughts/fixes?
Tue Jan 21, 2020 7:52 am
Chockymonster offline
Lights flashing randomly is normally a data issue when it comes to ws281x LEDs.
I'm not using Nodemcu stuff, my gear is all E.131 based with just under 7k LEDs on the house. I had this kind of issue with some of my receivers with a bad data connection so I'd start by looking there.
