Icon does not change whatever I do - CURTAINS
Wed Nov 06, 2019 10:57 am
mgolden50 offline
Re: Icon does not change whatever I do - CURTAINS
Hi Jay,
The device states are Thermostat A/C Equipment State (0n/0ff) & Heater Equipment State (on/off)
For AC, I have set the base image to Thermostat Cool Status 2x.png. [and I have replaced the png image with a blank image]
For Heat, I have set the base image to Thermostat Heat Status 2x.png [and I have replaced the png image with a blank image]
Instead of seeing nothing when the device is off, I see an outline drawing of the colored icon that shows when the device is on.
I what to superimpose the two images so that when either device is on I see the correct image for it.
And if both devices are of I see nothing--not the icon outline drawings.
Where do the outline drawings of the icons come from? They are not in the png images I've named.
Mike
Wed Nov 06, 2019 11:30 am
Can you take a screenshot?
Wed Nov 06, 2019 12:01 pm
mgolden50 offline
Here is a screen shot of my touch configured iPad, one of the configuration screen on my Mac, and a shot of the image.
Screen Shot 2019-11-06 at 10.59.11 AM.png (69.1 KiB) Viewed 3345 times
Wed Nov 06, 2019 12:03 pm
mgolden50 offline
I guess I have to send them one at time.
Wed Nov 06, 2019 12:07 pm
I'm talking about a screenshot of the "outline" you're seeing on the control page...
Wed Nov 06, 2019 12:13 pm
mgolden50 offline
icon outlines
Screen Shot 2019-11-06 at 11.12.03 AM.png (69.4 KiB) Viewed 3356 times
Wed Nov 06, 2019 12:31 pm
mgolden50 offline
Once again with smaller screen shot.
Notice how the snowflake is grey not blue on the iPad
Screen Shot 2019-11-06 at 11.30.49 AM.png (470.72 KiB) Viewed 3337 times
Wed Nov 06, 2019 1:58 pm
And you're sure that the A/C unit is actually on and cooling?
Wed Nov 06, 2019 2:42 pm
mgolden50 offline
Yes, both AC and heat turn on and work. And both icons switch as they should
from there outlines to their colored versions. But replacing the base images (which are outlines) with blank png’s doesn’t make the outlines disappear. And, I’ve delegated the outline versions from the directory.
Wed Nov 06, 2019 3:04 pm
RogueProeliator offline
That screenshot you posted a few posts back with the small thumbnails shows the outline in the thumbnail (Thermostat Cool Status 2x+.png) after you said it was blanked out. Could you have replaced in an old version's directory or something?
Wed Nov 06, 2019 3:14 pm
mgolden50 offline
My bad! In fact the blank png image had been replaced by the outline version. But since then (several messages back) I have doubly confirmed that the base image is indeed a blank png. And when I look in the directory and examine the images (by hitting space bar) the Thermostat Cool Status 2x.png is blank and the Thermostat Cool Status 2x+on.png image is a blue snowflake. So the issue persists
Wed Nov 06, 2019 3:17 pm
mgolden50 offline
Where could the outline image be coming from? Is there a cacheing issue somewheres?
Wed Nov 06, 2019 3:33 pm
mgolden50 offline
Caching was the problem!
I restarted the server and the client and it now works as expected. The outline images were apparently in the server cache.
Sorry for the disruption.
Mike
Wed Nov 06, 2019 3:51 pm
You shouldn't replace built-in images - the next time you upgrade Indigo they will get replaced with the built-in ones (and I don't think they'll get updated in Indigo Touch since we build those images directly into the app). Just duplicate and change the name of the ones with color, then they'll continue to work through upgrades.
And, yes, when you modify any existing image you have to restart the clients.
Wed Nov 06, 2019 4:26 pm
mgolden50 offline
Jay,
Thanks it's working perfectly now. I didn't realize I shouldn't mess with the built-in images and names. That was a major part of the problem plus not restarting after modifications. I couldn't find that info in the tutorials.
Mike
