Having one device track the state of another - in 1 trigger
Fri Jun 14, 2019 8:04 am
berkinet offline
I have two devices (both Z-Wave controlled lights, but that shouldn't really make a difference for this case) and I would like light 2 two track the state of light 1. That is, whenever light 1 turns on, light 2 should turn on and when light 1 turns off, light 2 should turn off. Light 1 does not need to track the state of light 2 (I.e. they do not always need to be in synch).
I can do this with two triggers, one for light 1's on-state and the other for the off-state. And, I can do it in 1 trigger (on any state change) with a few lines of scripting.
My question is: Is it possible to do this in one trigger without scripting?
Fri Jun 14, 2019 10:49 am
Re: Having one device track the state of another - in 1 trig
If they are both dimmers, you can use the Match Brightness action I think. Probably should have a similar "Match On State" or something for non-dimmables (that's on the list already).
Fri Jun 14, 2019 10:51 am
berkinet offline
jay (support) wrote:
If they are both dimmers...
...Probably should have a similar "Match On State" or something for non-dimmables (that's on the list already).
They are on/off. Thanks for the response.
Tue Jun 25, 2019 4:15 pm
mundmc offline
^ Just cut my triggers down by 5! Great question/ answer.
Wed Jun 26, 2019 6:59 am
jalves offline
I wonder if the Match Brightness action would work for virtual 3-way switches to keep them in sync. Hmmmm....
Running Indigo 7.3.1 on a 27" iMac (mid-2017), 40G memory, 1T Fusion Drive, OS X 10.14.6
Jeff
