Geofence not working
Thu May 16, 2019 10:11 am
lanbrown offline
Since the update my Geofencing has stopped working. It is no longer triggering when I leave or return home. Around that time I did change the names of the triggers an put a space at the front. When I discovered that they weren't working, if I added them back in I noticed that it updated the name with the space. Does DomoPad use the name or the Indigo ID? Anything I can do to troubleshoot the Geofencing not working on a Note 8 running Pie? It was working previously. The only changes were:
1) Return and Leave Action Groups I added a sapce to the front to bring them to the top of the list. I have since reverted back to no space at the front and it still doesn't work
2) Indigo 7.3.1
3) The latest version of the DomoPad Android app and the Indigo Plugin.
Thu May 16, 2019 12:34 pm
RogueProeliator offline
Re: Geofence not working
Man, I hate geofencing issues - they are a PITA to troubleshoot... So nothing changed on the application in regards to geofences, but (and this is a big one) the latest Google Play libraries which provide the enter/exit geofence events to the application was updated. I've been looking to put some more logging and viewing of the logs into the application, I might need to go ahead and do that for a beta this week.
Normally if a geofence fires and the action group cannot be executed it will show an execution notification -- do you get that at all? Might help determine if it is the fence or the sending of the action group. If no error, I suspect somehow the geofence boundary crossing is not reaching the app or I am not handling something correctly for the newest version of the services.
Thu May 16, 2019 3:21 pm
lanbrown offline
In the past I would get a failed execution at times as there are two low signal areas; one at each way I could get out but not at the same distance away, I have the geofence set for 700 meters. So I would sometimes get a notification that it failed to connect to run the action group. I have not received any of those notifications since the upgrade but after a 20 mile drive to work....it never fired. Likewise when I get home, it never fires. I have to manually run the action group. So there is no notification if it tried or not.
Thu May 16, 2019 5:07 pm
lanbrown offline
Got home a few minutes ago...no geofence trigger.
I just enabled the debug via the plugin option.
May 16, 2019 at 6:07:00 PM
   Domotics Pad Mobile Client      Debug enabled (on Low) by user
Thu May 16, 2019 8:39 pm
It sounds as if it is not getting the geofence notifications from the system. If you try to setup a new geofence, does it correctly get your current location?
If so, have you tried disabling, saving, and re-enabling it? That should not be required, of course, unless somehow it got "disconnected" during the update and it thinks the fence is in place and the system doesn't... would be a bug but just trying to think of the ways that it could go wrong from a configuration/processing standpoint.
Thu May 16, 2019 10:05 pm
lanbrown offline
I tried disabling it while at work today and then enabling it; it didn't trigger. So I now have it disabled and created a new one. I'll see tomorrow morning if it triggers or not.
Fri May 17, 2019 7:17 am
norcoscia offline
This does not seem to be working on my wife's Pixel either :-(
_______
Norm
Fri May 17, 2019 7:58 am
lanbrown offline
Yesterday I tried the disabling and enabling of geofence config and even made a slight change to the coordinates. Both didn't have any impact on it working or not. So I disabled it, took your suggestion and created a new one. This morning it did work. I have now deleted the previous config and renamed the new one the same as what the old one was.
Fri May 17, 2019 3:29 pm
Hmm, wonder if it is because I switched Google Play Services version... I'll be honestly, geofencing is the part of the app that gives me the most trouble because while I understand the concepts of geofencing, understanding the "best" way to utilize it in Android sure seems like a moving target. I just haven't stayed on top of the changes in that area... also hardest to test in general.
Please let me know if the newly created one continues to work for you.
@norcosicia -- can you try re-creating the geofence and disabling the old one?
Adam
Fri May 17, 2019 3:38 pm
norcoscia offline
OK, will do - it will be a bit before I can test since we just went shopping today. I will let you know :-)
_______
Norm
Fri May 17, 2019 4:38 pm
lanbrown offline
Well, the exit worked, the entering did not.
