Toggling Server Action from Lock to Unlock
Wed Apr 24, 2019 4:24 pm
Dave G offline
I installed the MyQ plugin and it works just fine - - as long as you only want the
garage door to “Unlock” (Open) or “Lock” (close). I cannot find anything with the plugin to toggle between lock and unlock states. I tried a couple of “if-else” Python codes in the “Server Action “ field on the Control Page but none worked.
As a temporary kludge, I dropped 2 garage door
Controls onto the Control Page with one control set to perform an “Open Door “ MyQ Action and the second garage door control to a “Close Door” action.
Obviously, this is an unsatisfactory way to open and close the Chamberlain garage door opener.
How can I get the MyQ plugin actions to toggle between “open” and “close”.
Wed Apr 24, 2019 4:56 pm
Re: Toggling Server Action from Lock to Unlock
If you want the plugin to implement a toggle action, file an enhancement request here: https://github.com/FlyingDiver/Indigo-MyQ/issues
If you want help figuring out how to do it in Indigo without a built-in toggle command, that's different. ;)
Doing it with a Python script is possible. Is that what you already tried? Post what you tried and we can help. The tricky part will be deciding what to do with all the states that aren't open or closed.
No time to write more now. Sorry.
Sun Jun 28, 2020 2:31 pm
wideglidejrp offline
Yale / Liftmaster Door Lock
The Yale / Lifemaster is a MyQ device. Does the plugin support this?
John R Patrick
Author of
Home Attitude
Sun Jun 28, 2020 2:35 pm
Re: Yale / Liftmaster Door Lock
Is that a lock? No idea, never tried one. But I would guess that it would probably work. The door opener is treated like a lock anyway.
If you get one, and it doesn't work, there's a menu item for the MyQ plugin called "Write MyQ Data to Log". Post that and I'll see if it can be made to work.
Sun Jun 28, 2020 3:09 pm
It is a door lock. Not garage door. See https://www.myq.com/smart-lock This page says it is a myQ device, but on Amazon it doesn't mention myQ. Its a branding fiasco. Yale, Liftmaster, Assure, myQ. I will call them tomorrow and get some clarification. Thanks for your offer of support.
John R Patrick
Author of
Home Attitude
