- Posted on
Sun Jul 07, 2019 8:41 am
brianlloyd
offline
Good morning Matt. Thanks for the help.
OK, changed the values and closed the windows. I closed the window and there was activity in the log. (See below.) I then did the sync again. This time it shows the new and old values for all four parameters. This is different behavior than what I saw before. See the log entries at the bottom of this message.
One other note, I did do an "Optimize network" last night late before I went to bed and when the network was mostly quiescent.
I then cycled the door up and down. No triggers.
I then followed your instructions to clear the association and then send the raw z-wave command. The full listing of the debug output is below. Sorry that the debug output is so voluminous. I have quite a few devices in my network. I included the entire listing from the time debug was turned on so you could see anything that might be significant.
FWIW, I still did not get updates on door state change. Now sending that commend to all the subdevices.
Still no effect. Everything should be in the log entries below.
Jul 7, 2019 at 09:03:42
Z-Wave Optimizing - device "083 - Hangar Door switch up - Binary 1" parameter 3 "Input 1 mode" changed to 138 "Trigger Between Thresholds - Report Analog Every 5 Minutes"
Z-Wave Optimizing - device "083 - Hangar Door switch up - Binary 1" parameter 5 "Input 1 OFF threshold LOW" changed to 1900
Z-Wave Optimizing - device "083 - Hangar Door switch up - Binary 1" parameter 7 "Input 1 ON threshold LOW" changed to 4090
Z-Wave Optimizing - device "083 - Hangar Door switch up - Binary 1" parameter 9 "Input 2 mode" changed to 138 "Trigger Between Thresholds - Report Analog Every 5 Minutes"
Trigger SetOfficeTempVariable
Jul 7, 2019 at 09:04:29
Z-Wave Optimizing - stopped
Z-Wave Optimizing - update queued for next awake message: "061 - Rear Door Lock"
Z-Wave Syncing - started for "Hangar Door switch up - Binary 1"
Z-Wave Syncing - retrieved module neighbors list: 43, 68, 70, 78
Z-Wave Syncing - assigning return route to "083 - Hangar Door switch up - Binary 1"
Z-Wave Syncing - retrieved manufacture and model names: FortrezZ - 0084, I/O Module (MIMO2+) - 04630208
Z-Wave Syncing - retrieved protocol version 4.34, app version 2.08
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : -- (04 : 21 : 00, base 31)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 85v1 86v1 71v1 8Ev1 70v1 31v9 72v1 73v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(21 : 00), 2:(21 : 00), 3:(10 : 01), 4:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[31 59 85 8E], 2:[31 59 85 8E], 3:[25 20 59], 4:[25 20 59]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 1 "Relay 1 mode" is 5 "Momentary (0.5 Second)"
Z-Wave Syncing - retrieved parameter 3 "Input 1 mode" is 138 "Trigger Between Thresholds - Report Analog Every 5 Minutes"
Z-Wave Syncing - retrieved parameter 4 "Input 1 OFF threshold HIGH" is 2496
Z-Wave Syncing - device "083 - Hangar Door switch up - Binary 1" parameter 4 "Input 1 OFF threshold HIGH" changed to 2500 (was 2496)
Z-Wave Syncing - retrieved parameter 5 "Input 1 OFF threshold LOW" is 1888
Z-Wave Syncing - device "083 - Hangar Door switch up - Binary 1" parameter 5 "Input 1 OFF threshold LOW" changed to 1900 (was 1888)
Z-Wave Syncing - retrieved parameter 6 "Input 1 ON threshold HIGH" is 4080
Z-Wave Syncing - device "083 - Hangar Door switch up - Binary 1" parameter 6 "Input 1 ON threshold HIGH" changed to 4095 (was 4080)
Z-Wave Syncing - retrieved parameter 7 "Input 1 ON threshold LOW" is 4080
Z-Wave Syncing - device "083 - Hangar Door switch up - Binary 1" parameter 7 "Input 1 ON threshold LOW" changed to 4090 (was 4080)
Z-Wave Syncing - retrieved parameter 2 "Relay 2 mode" is 5 "Momentary (0.5 Second)"
Z-Wave Syncing - retrieved parameter 9 "Input 2 mode" is 138 "Trigger Between Thresholds - Report Analog Every 5 Minutes"
Z-Wave Syncing - retrieved parameter 10 "Input 2 OFF threshold HIGH" is 2496
Z-Wave Syncing - device "083 - Hangar Door switch up - Binary 1" parameter 10 "Input 2 OFF threshold HIGH" changed to 2500 (was 2496)
Z-Wave Syncing - retrieved parameter 11 "Input 2 OFF threshold LOW" is 2000
Z-Wave Syncing - retrieved parameter 12 "Input 2 ON threshold HIGH" is 4080
Z-Wave Syncing - device "083 - Hangar Door switch up - Binary 1" parameter 12 "Input 2 ON threshold HIGH" changed to 4095 (was 4080)
Z-Wave Syncing - retrieved parameter 13 "Input 2 ON threshold LOW" is 4080
Z-Wave Syncing - device "083 - Hangar Door switch up - Binary 1" parameter 13 "Input 2 ON threshold LOW" changed to 4094 (was 4080)
Z-Wave Syncing - complete
Z-Wave sent "Hangar Door switch up - Binary 1" status request
Z-Wave received "Hangar Door switch up - Analog 1" sensor update to 3072
Z-Wave sent "Hangar Door switch up - Analog 1" status request
Z-Wave sent "Hangar Door switch down - Binary 2" status request
Z-Wave received "Hangar Door switch down - Analog 2" sensor update to 1
Z-Wave sent "Hangar Door switch down - Analog 2" status request
Z-Wave received "Hangar Door switch down - Analog 2" sensor update to 2
Z-Wave sent "Hangar Door Control Open - Relay 1" status request
Z-Wave sent "Hangar Door Control Close - Relay 2" status request
Jul 7, 2019 at 09:10:24
Z-Wave sent "Hangar Door Control Open - Relay 1" on
Z-Wave received "Hangar Door Control Open - Relay 1" status update is off
Jul 7, 2019 at 09:11:41
Z-Wave sent "Hangar Door Control Close - Relay 2" on
Z-Wave received "Hangar Door Control Close - Relay 2" status update is off
Jul 7, 2019 at 09:22:45
Z-Wave received "081 - Meter Total" power load to 6682.091 W
Z-Wave received "081 - Meter Total" energy total to 14077.461 kWh
Z-Wave received "081 - Clamp 1" power load to 3448.086 W
Z-Wave received "081 - Clamp 2" power load to 3234.005 W
Z-Wave received "081 - Clamp 1" energy total to 7520.611 kWh
Z-Wave received "081 - Clamp 2" energy total to 6556.850 kWh
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
Z-Wave Debug . . getVersion: requeuing 1 unsolicited packets
Z-Wave Debug . . getVersion: Z-Wave 3.95 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 C8 C4 7C 37 01 90
Z-Wave Debug . . getHomeID: requeuing 1 unsolicited packets
Z-Wave Debug . . getHomeID: C8C47C37, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7
Z-Wave Debug . . getInterfaceFeatures: requeuing 1 unsolicited packets
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 00 00 86 01 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FA
Z-Wave Debug . . getInterfaceApiCapabilities: requeuing 1 unsolicited packets
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.00, manufactureId 0086, productType 0101, productId 005A
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem143301 (firmware 1.00)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug . . forceSUC: requeuing 1 unsolicited packets
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D FF DF 7F FF DF E7 27 BE 7F 22 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 97
Z-Wave Debug . . getInitialNodeData: requeuing 1 unsolicited packets
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 15, 16, 17, 18, 19, 20, 21, 22, 23, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 39, 40, 41, 42, 43, 46, 47, 48, 49, 50, 51, 54, 58, 59, 60, 61, 62, 64, 65, 66, 67, 68, 69, 70, 71, 74, 78, 81, 82, 83]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33
Z-Wave Debug . . getNodeProtocolInfo: requeuing 1 unsolicited packets
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 04 E8
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Dimmable Scene Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Scene Switch (04 : 11 : 04)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27 2B 2C 72
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 03 EE
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Relay Scene Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Scene Switch (04 : 10 : 03)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27 2B 2C 72
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 04 BE
Z-Wave Debug . . getNodeProtocolInfo: node 004, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 20 01 DD
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Binary Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 30
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 30
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 09 B3
Z-Wave Debug . . getNodeProtocolInfo: node 009, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0A B0
Z-Wave Debug . . getNodeProtocolInfo: node 010, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0B B1
Z-Wave Debug . . getNodeProtocolInfo: node 011, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0C B6
Z-Wave Debug . . getNodeProtocolInfo: node 012, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0D B7
Z-Wave Debug . . getNodeProtocolInfo: node 013, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0F B5
Z-Wave Debug . . getNodeProtocolInfo: node 015, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 10 AA
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 08 06 F3
Z-Wave Debug . . getNodeProtocolInfo: node 016, class name: General Thermostat (v2)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 40
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 40 72 43 86
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 11 AB
Z-Wave Debug . . getNodeProtocolInfo: node 017, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 12 A8
Z-Wave Debug . . getNodeProtocolInfo: node 018, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 13 A9
Z-Wave Debug . . getNodeProtocolInfo: node 019, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 14 AE
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 020, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug overriding node 020 type from zwDimmerType to zwColorDimmerType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 15 AF
Z-Wave Debug . . getNodeProtocolInfo: node 021, class name: Dimmable Power Switch
Z-Wave Debug overriding node 021 type from zwDimmerType to zwColorDimmerType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 16 AC
Z-Wave Debug . . getNodeProtocolInfo: node 022, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 17 AD
Z-Wave Debug . . getNodeProtocolInfo: node 023, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 19 A3
Z-Wave Debug . . getNodeProtocolInfo: node 025, class name: Dimmable Power Switch
Z-Wave Debug overriding node 025 type from zwDimmerType to zwColorDimmerType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1A A0
Z-Wave Debug . . getNodeProtocolInfo: node 026, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1B A1
Z-Wave Debug . . getNodeProtocolInfo: node 027, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1C A6
Z-Wave Debug . . getNodeProtocolInfo: node 028, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1D A7
Z-Wave Debug . . getNodeProtocolInfo: node 029, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1E A4
Z-Wave Debug . . getNodeProtocolInfo: node 030, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1F A5
Z-Wave Debug . . getNodeProtocolInfo: node 031, class name: Dimmable Power Switch
Z-Wave Debug overriding node 031 type from zwDimmerType to zwColorDimmerType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 20 9A
Z-Wave Debug . . getNodeProtocolInfo: node 032, class name: Dimmable Power Switch
Z-Wave Debug overriding node 032 type from zwDimmerType to zwColorDimmerType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 21 9B
Z-Wave Debug . . getNodeProtocolInfo: node 033, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 22 98
Z-Wave Debug . . getNodeProtocolInfo: node 034, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 23 99
Z-Wave Debug . . getNodeProtocolInfo: node 035, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 24 9E
Z-Wave Debug . . getNodeProtocolInfo: node 036, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 25 9F
Z-Wave Debug . . getNodeProtocolInfo: node 037, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 27 9D
Z-Wave Debug . . getNodeProtocolInfo: node 039, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 28 92
Z-Wave Debug . . getNodeProtocolInfo: node 040, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 29 93
Z-Wave Debug . . getNodeProtocolInfo: node 041, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2A 90
Z-Wave Debug . . getNodeProtocolInfo: node 042, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2B 91
Z-Wave Debug . . getNodeProtocolInfo: node 043, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2E 94
Z-Wave Debug . . getNodeProtocolInfo: node 046, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2F 95
Z-Wave Debug . . getNodeProtocolInfo: node 047, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 30 8A
Z-Wave Debug . . getNodeProtocolInfo: node 048, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 31 8B
Z-Wave Debug . . getNodeProtocolInfo: node 049, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 32 88
Z-Wave Debug . . getNodeProtocolInfo: node 050, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 33 89
Z-Wave Debug . . getNodeProtocolInfo: node 051, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 36 8C
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 21 01 DC
Z-Wave Debug . . getNodeProtocolInfo: node 054, class name: Multilevel Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 31
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 31
Z-Wave Debug overriding node 054 type from zwValueSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3A 80
Z-Wave Debug . . getNodeProtocolInfo: node 058, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3B 81
Z-Wave Debug . . getNodeProtocolInfo: node 059, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3C 86
Z-Wave Debug . . getNodeProtocolInfo: node 060, class name: Dimmable Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3D 87
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 DC 00 04 40 03 7E
Z-Wave Debug . . getNodeProtocolInfo: node 061, class name: Keypad Door Lock
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 62
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 62 63 86 72 98
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming, security, frequentWaking
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3E 84
Z-Wave Debug . . getNodeProtocolInfo: node 062, class name: Keypad Door Lock
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 40 FA
Z-Wave Debug . . getNodeProtocolInfo: node 064, class name: Keypad Door Lock
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 41 FB
Z-Wave Debug . . getNodeProtocolInfo: node 065, class name: Multilevel Sensor (routing)
Z-Wave Debug overriding node 065 type from zwValueSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 42 F8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 066, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 43 F9
Z-Wave Debug . . getNodeProtocolInfo: node 067, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 44 FE
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 0F 01 F3
Z-Wave Debug . . getNodeProtocolInfo: node 068, class name: Basic Repeater Slave
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Repeater Slave : Basic Repeater Slave (04 : 0F : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 45 FF
Z-Wave Debug . . getNodeProtocolInfo: node 069, class name: Basic Repeater Slave
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 46 FC
Z-Wave Debug . . getNodeProtocolInfo: node 070, class name: Relay Scene Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 47 FD
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 071, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 4A F0
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 1C 01 04 40 07 3B
Z-Wave Debug . . getNodeProtocolInfo: node 074, class name: Secure Barrier Add-On
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Entry Control : Secure Barrier Add-On (04 : 40 : 07)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 66
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 66
Z-Wave Debug overriding node 074 type from zwLockType to zwRelayType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 4E F4
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 08 06 F2
Z-Wave Debug . . getNodeProtocolInfo: node 078, class name: General Thermostat (v2)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 51 EB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 31 01 CC
Z-Wave Debug . . getNodeProtocolInfo: node 081, class name: Simple Meter
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Meter : Simple Meter (04 : 31 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 32
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 32 72 86
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 52 E8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 082, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 53 E9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 21 00 DD
Z-Wave Debug . . getNodeProtocolInfo: node 083, class name: Multilevel Sensor
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Multilevel Sensor : -- (04 : 21 : 00)
Z-Wave Debug overriding node 083 type from zwValueSensorType to zwOnOffSensorType
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 20 06 31 05 04 22 00 AF 6C
Z-Wave Debug . . requestVarSensorStatus: node 032, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 17.5 W (float: 17.500000)
Z-Wave Debug received "Office counter - composite" power load to 17.5 W
Jul 7, 2019 at 09:23:21
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 53 0A 60 0D 01 00 31 05 02 0A 0C 02 EC
Z-Wave Debug . . multiEndPointPacket: node 083, endPoint 1
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 53 06 31 05 02 0A 0C 02 FF
Z-Wave Debug . . requestVarSensorStatus: node 083, endpoint 1, type 2, raw value 0A0C...
Z-Wave Debug . . requestVarSensorStatus: 3074 (float: 3074.000000)
Z-Wave received "Hangar Door switch up - Analog 1" sensor update to 3074
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 53 0A 60 0D 02 00 31 05 02 0A 00 11 F0
Z-Wave Debug . . multiEndPointPacket: node 083, endPoint 2
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 53 06 31 05 02 0A 00 11 FF
Z-Wave Debug . . requestVarSensorStatus: node 083, endpoint 2, type 2, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 17 (float: 17.000000)
Z-Wave received "Hangar Door switch down - Analog 2" sensor update to 17
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 20 06 31 05 04 22 00 B0 73
Z-Wave Debug . . requestVarSensorStatus: 17.6 W (float: 17.600000)
Z-Wave Debug received "Office counter - composite" power load to 17.6 W
Jul 7, 2019 at 09:23:47
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 05 06 31 05 03 0A 02 37 FC
Z-Wave Debug . . requestVarSensorStatus: node 005, endpoint None, type 3, raw value 0A02...
Z-Wave Debug . . requestVarSensorStatus: 567 lux (float: 567.000000)
Z-Wave Debug received "Office Luminance" sensor update to 567 lux
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 05 06 31 05 05 01 21 00 E5
Z-Wave Debug . . requestVarSensorStatus: node 005, endpoint None, type 5, raw value 0121...
Z-Wave Debug . . requestVarSensorStatus: 33% (float: 33.000000)
Z-Wave Debug received "Office Humidity" sensor update to 33%
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 05 06 31 05 01 2A 03 01 E9
Z-Wave Debug . . requestVarSensorStatus: node 005, endpoint None, type 1, raw value 2A03...
Z-Wave Debug . . requestVarSensorStatus: 76.9 °F (float: 76.900000)
Z-Wave Debug received "Office Temperature" sensor update to 76.9 °F
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 17 06 31 05 03 0A 00 01 DA
Z-Wave Debug . . requestVarSensorStatus: node 023, endpoint None, type 3, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 1 lux (float: 1.000000)
Z-Wave Debug received "Garage Luminance" sensor update to 1 lux
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 17 06 31 05 05 01 35 00 E3
Z-Wave Debug . . requestVarSensorStatus: node 023, endpoint None, type 5, raw value 0135...
Z-Wave Debug . . requestVarSensorStatus: 53% (float: 53.000000)
Z-Wave Debug received "Garage Humidity" sensor update to 53%
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 17 06 31 05 01 2A 03 6D 97
Z-Wave Debug . . requestVarSensorStatus: node 023, endpoint None, type 1, raw value 2A03...
Z-Wave Debug . . requestVarSensorStatus: 87.7 °F (float: 87.700000)
Z-Wave Debug received "Garage temperature" sensor update to 87.7 °F
Z-Wave Debug SENT removeAssociation: 01 0B 00 13 53 04 85 04 01 01 25 A3 B7
Z-Wave removed association of "001 - Indigo Z-Wave Interface" from "Hangar Door switch up - Binary 1" group 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 53 03 85 02 01 25 A4 B1
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 53 05 85 03 01 02 00 23
Z-Wave Debug . . requestAssociations: node 083, group: 1, num associations: 0, max associations: 2, replies left: 0
Z-Wave Debug . . requestAssociations: node 083, group: 1, associations: []
Z-Wave retrieved group 1 associations: []
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 20 06 31 05 04 22 00 B4 77
Z-Wave Debug . . requestVarSensorStatus: 18.0 W (float: 18.000000)
Z-Wave Debug received "Office counter - composite" power load to 18.0 W
Jul 7, 2019 at 09:24:27
Jul 7, 2019 at 09:24:57
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 20 06 31 05 04 22 00 B3 70
Z-Wave Debug . . requestVarSensorStatus: 17.9 W (float: 17.900000)
Z-Wave Debug received "Office counter - composite" power load to 17.9 W
Jul 7, 2019 at 09:25:27
Jul 7, 2019 at 09:25:51
Z-Wave Debug SENT sendRawZwaveCommand: 01 29 00 13 53 22 60 0D 01 01 8E 01 01 00 01 01 8E 01 01 00 01 01 8E 01 01 00 01 01 8E 01 01 00 01 01 8E 01 01 00 01 01 25 A5 D7
Z-Wave sent "Hangar Door switch up - Analog 1" raw command [8E 01 01 00 01 01 8E 01 01 00 01 01 8E 01 01 00 01 01 8E 01 01 00 01 01 8E 01 01 00 01 01]
Jul 7, 2019 at 09:26:27
Jul 7, 2019 at 09:26:47
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 53 07 60 0D 01 03 25 01 FF 25 A6 81
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 53 07 60 0D 03 01 25 03 FF 14
Z-Wave Debug . . multiEndPointPacket: node 083, endPoint 3
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 53 03 25 03 FF FF
Z-Wave Debug . . requestRelayStatus: node 083, endpoint 3, value 255
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 53 07 60 0D 03 01 25 03 00 EB
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 53 03 25 03 00 FF
Z-Wave Debug . . requestRelayStatus: node 083, endpoint 3, value 0
Jul 7, 2019 at 09:27:25
Z-Wave Debug RCVD requestVarSensorStatus: 01 0B 00 04 00 10 05 31 05 01 09 4A 93
Z-Wave Debug . . requestVarSensorStatus: node 016, endpoint None, type 1, raw value 094A...
Z-Wave Debug . . requestVarSensorStatus: 74 °F (float: 74.000000)
Z-Wave received "Thermostat, house" temperature update to 74 °F
Trigger Set HouseTempVariable
Z-Wave Debug RCVD setFanState: 01 09 00 04 00 10 03 45 03 00 A7
Z-Wave Debug . . setFanState: node 016, endpoint None, value 0
Z-Wave received "Thermostat, house" fan is off
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 20 06 31 05 04 22 00 B5 76
Z-Wave Debug . . requestVarSensorStatus: 18.1 W (float: 18.100000)
Z-Wave Debug received "Office counter - composite" power load to 18.1 W
Jul 7, 2019 at 09:27:47
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 05 06 31 05 03 0A 03 22 E8
Z-Wave Debug . . requestVarSensorStatus: node 005, endpoint None, type 3, raw value 0A03...
Z-Wave Debug . . requestVarSensorStatus: 802 lux (float: 802.000000)
Z-Wave Debug received "Office Luminance" sensor update to 802 lux
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 05 06 31 05 05 01 20 00 E4
Z-Wave Debug . . requestVarSensorStatus: node 005, endpoint None, type 5, raw value 0120...
Z-Wave Debug . . requestVarSensorStatus: 32% (float: 32.000000)
Z-Wave Debug received "Office Humidity" sensor update to 32%
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 05 06 31 05 01 2A 02 FF 16
Z-Wave Debug . . requestVarSensorStatus: node 005, endpoint None, type 1, raw value 2A02...
Z-Wave Debug . . requestVarSensorStatus: 76.7 °F (float: 76.700000)
Z-Wave Debug received "Office Temperature" sensor update to 76.7 °F
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 53 07 60 0D 01 04 25 01 FF 25 A7 87
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 53 07 60 0D 04 01 25 03 FF 13
Z-Wave Debug . . multiEndPointPacket: node 083, endPoint 4
Z-Wave Debug . . requestRelayStatus: node 083, endpoint 4, value 255
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 53 07 60 0D 04 01 25 03 00 EC
Z-Wave Debug . . requestRelayStatus: node 083, endpoint 4, value 0
Jul 7, 2019 at 09:28:21
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 53 0A 60 0D 01 01 31 05 02 0A 0C 02 ED
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 53 0A 60 0D 02 01 31 05 02 0A 0C 02 EE
Z-Wave Debug . . requestVarSensorStatus: node 083, endpoint 2, type 2, raw value 0A0C...
Z-Wave received "Hangar Door switch down - Analog 2" sensor update to 3074
(Sent Z-wave commands to other devcies)
Jul 7, 2019 at 09:34:21
Z-Wave Debug SENT sendRawZwaveCommand: 01 11 00 13 53 0A 60 0D 01 01 8E 01 01 00 01 01 25 AE CC
Z-Wave sent "Hangar Door switch up - Analog 1" raw command [8E 01 01 00 01 01]
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 20 06 31 05 04 22 00 B1 72
Z-Wave Debug . . requestVarSensorStatus: 17.7 W (float: 17.700000)
Z-Wave Debug received "Office counter - composite" power load to 17.7 W
Z-Wave Debug SENT sendRawZwaveCommand: 01 11 00 13 53 0A 60 0D 01 01 8E 01 01 00 01 01 25 AF CD
Z-Wave Debug SENT sendRawZwaveCommand: 01 11 00 13 53 0A 60 0D 01 02 8E 01 01 00 01 01 25 B0 D1
Z-Wave sent "Hangar Door switch down - Analog 2" raw command [8E 01 01 00 01 01]
Z-Wave Debug SENT sendRawZwaveCommand: 01 11 00 13 53 0A 60 0D 01 02 8E 01 01 00 01 01 25 B1 D0
Z-Wave Debug SENT sendRawZwaveCommand: 01 11 00 13 53 0A 60 0D 01 03 8E 01 01 00 01 01 25 B2 D2
Z-Wave sent "Hangar Door Control Open - Relay 1" raw command [8E 01 01 00 01 01]
Z-Wave Debug SENT sendRawZwaveCommand: 01 11 00 13 53 0A 60 0D 01 04 8E 01 01 00 01 01 25 B3 D4
Z-Wave sent "Hangar Door Control Close - Relay 2" raw command [8E 01 01 00 01 01]
(Cycled the door again)
Jul 7, 2019 at 09:36:15
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 53 07 60 0D 01 03 25 01 FF 25 B4 93
Jul 7, 2019 at 09:36:57
Jul 7, 2019 at 09:37:21
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 53 07 60 0D 01 04 25 01 FF 25 B5 95
