Remote access to server
Sat Feb 09, 2019 2:04 am
indigo2200 offline
Thanks for a rock solid product. Just returned from a trip abroad. While in a plane somewhere in Asia I turned the heat on in my deep frozen Scandinavian home thousands of miles away.
Been wondering if I can assess the server remotely (the full client interface)? While on my home network I do this constantly from the client software on my Macbook Air, but that is limited to when I am actually on my local wifi-network. Would it be possible to assess from anywhere? Did I overlook something?
Sat Feb 09, 2019 2:43 am
berkinet offline
Re: Remote access to server
try https://wiki.indigodomo.com/doku.php?id ... reflectors
Sat Feb 09, 2019 6:23 am
Two more options:
It is also possible to use direct access without the reflector service, which is what I do (I use the reflector service for Indigo Touch). There's absolutely nothing wrong with the reflector service--it works great!
1. You need to know the WAN IP that your ISP has assigned you (I set up a small Python script to save the Indigo server's WAN IP to an Indigo variable because mine changes regularly.) Then I can whip out Indigo Touch to get the current IP, and--with the Indigo client software on the MacBook--connect to this the WAN IP. This method requires your Internet security (router, firewall, etc.) to be setup to allow you to do this. Since you're able to connect remotely with Indigo Touch, you should be able to make this work. There are also dynamic DNS services that will do this IP tracking and routing for you (you attach using a static IP or DNS name that the service gives you).
2. More recently, I've been connecting to my home network via a VPN service that I'm hosting locally on my Ubiquiti router. Once the MacBook's successfully attached to the VPN, I connect to the LAN IP of my Indigo server. The company makes available a complementary dynamic DNS service for its products. This is my preferred approach because I then have much more access to other things on my home network. There are a few small limitations, but this approach is nearly identical to how it works when I'm sitting on the couch.
Both work like a champ.
Sat Feb 09, 2019 1:50 pm
neilk offline
If the request is to run the Mac desktop client, as I presume from the original post remote access is already covered.
Nothing in the native Indigo functionality for that use case but I use two methods.
1) TeamViewer which is free for personal use and is generally robust (they did release a point release with Mac issues). Other Remote Desktop approaches are of course possible and people have different views on the security and privacy implications of a cloud service for this but is is easy to use and set up. I also use the two factor feature they added after a well documented issue they had.
2) I have a VPN setup with my UniFi Security Gateway and with that you can then use the full client (other VPN tools and approaches may work just as well). This again works very well. If the server is unresponsive then I can SSH in locally once on the VPN and at least reboot.
It is useful to have both as different activities, access issues with throttled hotel Wi-fi can be better suited to one approach versus the other.
In most cases teamviewer is my first choice for simple access, but be careful to quit the client at the end of the session on your server machine as if you suffer from the client memory leak issue teamviewer will also not respond on the server either. In that case I either VPN in or TeamViewer into to my BlueJris box and SSH from that.
One thing I can guarantee is that rare as that issues are with Indigo it does seem to have an inbuilt geofence that knows I am travelling and in an awkward time zone as a time to crash (I know this is a general Home Automation phenomenon.
Sat Feb 09, 2019 3:55 pm
indigo2200 offline
Great - thanks all of you!
