Foxx Project Water Sensor
Sat Dec 08, 2018 1:44 pm
juntta offline
I found these (binary) water at Amazon Black Friday deals for 15€ and decided to give them a go.
https://www.getfoxx.com/product-page/foxx-project-z-wave-water-level-sensor
https://www.amazon.co.uk/d/Home-Kitchen/FPZWWS-Z-Wave-Water-Sensor-White/B014JS581E/ref=sr_1_3?ie=UTF8&qid=1544296847&sr=8-3&keywords=foxx+water+sensor
Pretty small sensor (10 x 5 x 6 cm), powered by 2 AAA batteries. Sensor has about 0,5m cord with small plug at the end with two metal sensor pins. Sensor seems to be rebranded Aeotec sensors since Indigo recognizes them as manufactured by Aeotec but model definitions didn't match with any model.
Anyway, they work as binary sensor and they can be triggered at least by on/off state which is suitable at the moment. Device parameters can't be edited from Edit Device Settings dialog but has to be done through z-wave configuration parameters.
Manual: http://store.zwavecenter.com/image/catalog/PDF/Foxx_Flood_Sensor_BC.pdf
Here is the device definition and sync details:
   Z-Wave                          Syncing - started for "071 - Binary Sensor (routing)"
   Z-Wave                          Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 10, 11, 13, 14, 15, 16, 17, 18, 19, 22, 23, 24, 28, 32, 39, 40, 47, 51, 52, 53, 54, 56, 57, 58, 59, 61, 62, 63, 64, 69
   Z-Wave                          Syncing - assigning return route to "071 - Binary Sensor (routing)"
   Z-Wave                          Syncing - assigned return route
   Z-Wave                          Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Binary Sensor (routing) - 0002002D
   Z-Wave                          Syncing - retrieved protocol version 3.67, app version 1.05
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01, base 30)
   Z-Wave                          Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 71v1 72v1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, waking
   Z-Wave                          Syncing - retrieved wake interval of 60 minutes
   Z-Wave                          Syncing - device "071 - Binary Sensor (routing)" wake interval changed to 60 minutes
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave                          Syncing - added group 1 association to interface
   Z-Wave                          Syncing - retrieved battery level of 100%
   Z-Wave                          Syncing - created device "071 - Binary Sensor (routing)"
   Z-Wave                          Syncing - complete
   Z-Wave                          sent "071 - Binary Sensor (routing)" status request
   Z-Wave                          received "071 - Binary Sensor (routing)" status update battery level 100%
Indigo Z-Wave Version: 2.0.119
Node ID: 71
Model: Binary Sensor (routing)
Model ID: 0002002D
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.67
Application Version: 1.05
Model Definition Version: 0
Library Type: 3
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 71v1 72v1
Features: routing, battery, beaming, waking
Neighbors: 2, 3, 4, 5, 6, 7, 8, 10, 11, 13, 14, 15, 16, 17, 18, 19, 22, 23, 24, 28, 32, 39, 40, 47, 51, 52, 53, 54, 56, 57, 58, 59, 61, 62, 63, 64, 69
Associations: 1:[1]
Config Values: - none -
Sat Dec 08, 2018 3:03 pm
Re: Foxx Project Water Sensor
Looks like this is an OEM of the Aeotec DSB45. Indigo has the Aeotec Water Sensor 6 defined but not yet the DSB45. I'll add it to the ToDo list.
Sat Dec 08, 2018 3:32 pm
siclark offline
Is that their old water sensor? Non Gen5 and no temp reporting but if it works that's a great price for water detection.
Sun Dec 09, 2018 12:34 am
juntta offline
No temp sensor and not gen5 but for the price and versatility it is great find: besides water detection I have one installed to my battery operated doorbell and one to my DIY mousetrap!
Users browsing this forum: Korey and 8 guests
