Switchboard Error in plugin execution
Fri Nov 09, 2018 10:56 am
Rickk offline
Hello, I love Switchboard but I've having some issues.
Here's the latest error
Received RF security command sensor alert (max delay) (ID 55)
Switchboard Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 799, in x10CommandReceived
File "plugin.py", line 731, in check_X10_Heartbeats
ValueError: could not convert string to float:
Received RF security command sensor normal (max delay) (ID 55)
Any Ideas of what's going on and/or how to resolve it.
Thanks a ton
Rick Kirchner
Fri Nov 09, 2018 11:40 am
bschollnick2 offline
Re: Switchboard Error in plugin execution
Rick,
I'll try to check the code tonight, and see if there is anything there.
Can you please email me at Benjamin AT schollnick DOT net, and I'll get a debug version of the plugin to you.
I can't think of a reason for this, but obviously something is happening...
My Plugins for Indigo (v4, v5, and v6) - http://bit.ly/U8XxPG
Security Script for v4 - http://bit.ly/QTgclf
for v5 - http://bit.ly/T6WBKu
Support Forum(s) - http://www.perceptiveautomation.com/userforum/viewforum.php?f=33
Fri Nov 09, 2018 1:11 pm
Rickk offline
I sent the email.
Thanks a lot for the quick response.
Sun Nov 11, 2018 6:04 am
Rickk wrote:
I sent the email.
No problem. Glad to try to help out.
Something is very strange here...
timeout = float(indigo.devices[Indigo_Device_ID].globalProps[plugin_id]["X10HeartBeatTimeOut"]) * 60.0
I'm assuming since it's the checkforX10 routine is being called that this is an X10 device?
Go into that switchboard device:
* what is the "Turn Off heartbeat warnings" set to?
* If you turn on "Override the heartbeat timeout of this device", and then scroll down, what is in the box that is revealed?
Switchboard is trying to read the value for X10HeartBeatTimeOut, and convert it to a numeric value. For some reason, it's acting like there is a non-numeric value in that field?
