Indigo Backup for 7.2?
Sat Nov 03, 2018 1:00 pm
Korey offline
Any live links to download the backup plugin?
They all seem to be 404.
Since I upgraded to 7.2 the plugin still is backing up my old 7.0 folders, any way to change this?
Korey
Sat Nov 03, 2018 1:21 pm
Re: Indigo Backup for 7.2?
Sat Nov 03, 2018 9:24 pm
Korey offline
Thanks for the tip!
using your utilities plugin already!
I'll start using the backup too.
Feature Request: when you are bored, add an option to back up everything in the:
/Library/Application Support/Perceptive Automation/Indigo 7.2
Folder
As well as Option to compress? (Zip)
Thanks!! :P
Korey
Sun Nov 04, 2018 4:34 am
It's not mine.
Sun Nov 04, 2018 3:39 pm
it actually offers backup for sqlite, postres, and indigo config / prefs files. Everything else is almost static.
You could do a once a week zip manually or in a little script (schedule/action/server action/ execute script):
import subprocess
subprocess.Popen("/usr/bin/zip  -r /users/YOURID/indigodir.zip '/Library/Application Support/Perceptive Automation/Indigo 7.2'  &",shell=True)
Sun Nov 04, 2018 3:56 pm
Or just use Time Machine....
Sun Nov 04, 2018 6:46 pm
Korey offline
Sorry got you guys mixed up, I thought Karl's plugin you mentioned was yours Joe!
I do backup to time machine, but this plugin was great as it would backup each day to a separate zip file so Backblaze could back up indigo, (Backblaze does not permit backing up of the Library folders :? )
I am actually using the Indigo Utilities plugin as well.
Image 11-4-18 at 3.38 PM.jpg (44.38 KiB) Viewed 1717 times
Korey
Sat Nov 17, 2018 8:10 am
Ramias offline
Just noticed this as I was checking a backup before attempting an upgrade to Mojave...
In the plugin folder for Indigo Backup, file plugin.py there is a function starting on line 80:
 80           def     return_indigo_path ( self ):
 81         #
 82         #       Next Generation iws path calculation
 83         #
 84         #       Uses the Indigo Server version to generate the IWS path
 85         #
 86                 return r"/library/Application Support/Perceptive Automation/Indigo %s/" % (int(indigo.server.version[0]) )
Line 86 is only returning the first character (the "0" in the brackets) of Indigo Version, which is now 7.2.0 and using that for the path.
Changing that bracket to return the first three characters of the version string with a "[:3]" allows it to get the 7.2 and use that for the correct path to backup.
But that makes it no longer an int so need to change that to a str.
so make line 86 look like this:
return r"/library/Application Support/Perceptive Automation/Indigo %s/" % (str(indigo.server.version[:3]) )
Sat Nov 17, 2018 9:34 am
Or just use the built-in server method:
indigo.server.getInstallFolderPath()
Which will always work... :D
Sat Nov 17, 2018 11:22 am
Korey offline
 81         #
 83         #
 85         #
Thanks for the tip! that fixed it!
I must have an older version of the plugin (0.96) as your line 86 is my line 60..
Korey
Tue Nov 20, 2018 9:51 pm
Ramias offline
In case anybody is interested I have attached my edited version of plugin.py that fixes the path issue (Thanks Jay) and also changes the backup file name so it is just .zip and not .zip.zip. Copy this into your /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Indigo Backup.indigoPlugin/Contents/Server Plugin directory.
of course, drop the .txt extension.
plugin.py.txt
(4.15 KiB) Downloaded 86 times
Wed Nov 21, 2018 10:53 am
Korey offline
Korey
Tue Nov 27, 2018 1:59 pm
bschollnick2 offline
Well, we learn something every day. I'll have to take a look and update my code...
- Ben
My Plugins for Indigo (v4, v5, and v6) - http://bit.ly/U8XxPG
Security Script for v4 - http://bit.ly/QTgclf
for v5 - http://bit.ly/T6WBKu
Support Forum(s) - http://www.perceptiveautomation.com/userforum/viewforum.php?f=33
Tue Nov 27, 2018 6:09 pm
Slight correction: it will always work on Indigo 6+ (was introduced in API v1.10 which was one of the Indigo 6 betas).
