iMessage Indigo Plugin [New Plugin]
Mon Jan 14, 2019 9:32 pm
GlennNZ offline
bjones wrote:
GlennNZ wrote:
bjones wrote:
Hello! Is there a ways to enable full disk access on macOS Sierra?
If not, is it safe to say this is not compatible with older versions? Thanks!
Not sure. Didn’t think it {full disk access change} was needed - as the restricted disk access part of increased security in High Sierra and above..
Quick google should answer...
Would think should work fine on older versions - but remains untested by me.
Glenn
Hey Glenn, the only issue I am having is my inbound messages don't seem to register. I can send outbound messages just fine. I'm wondering if these are being blocked somehow.
Any suggestions? Thanks!
Might be disk access issue equivalent - as would have that effect
Turn debug logging on and pm me the result, and I’ll google disk access Sierra when I stop
moving ....
Glenn
Mon Jan 14, 2019 11:28 pm
GlennNZ offline
Re: iMessage Indigo Plugin [New Plugin]
Hi
Quick google - think Sierra and below need to alter 'permissions' given lack of full disk access.
For
~/Library/Messages/
particularly the file
~/Library/Messages/chat.db
This is the sql messages database the plugin reads (only reads) to get incoming messages and attachments (the mp4 audio files)
Should only need to be read access.
https://support.apple.com/kb/PH25287?locale=en_US
Someone with more Mac OS experience than me might like to chime in.. but give this a go in the first instance.
Glenn
Sat Jan 19, 2019 7:30 am
bjones offline
Sorry for the delay, Glenn!
I added the permissions to the items enclosed in the messages folder at your recommendation, restarted the plugin, and can't seem to receive messages (I've been able to send from indigo to my buddy device).
It does confirm that it connects to the database, I wonder if something is off with my config but I believe I've followed all of the steps correctly. Thanks!
Here's the log:
 iMessage Plugin Debug           Restarting/or error. Stopping  thread.
   iMessage Plugin Debug           connectsql() method called.
   iMessage Plugin Debug           Removing Trigger Test iMessage Trigger (1978200985)
   iMessage Plugin Debug           shutdown() method called.
   Stopped plugin "iMessage Plugin 0.1.4"
   Starting plugin "iMessage Plugin 0.1.4" (pid 83849)
   iMessage Plugin
   iMessage Plugin                 ================================================ Initializing New Plugin Session =================================================
   iMessage Plugin                 Plugin name:                   iMessage Plugin
   iMessage Plugin                 Plugin version:                0.1.4
   iMessage Plugin                 Plugin ID:                     com.GlennNZ.indigoplugin.iMessage
   iMessage Plugin                 Indigo version:                7.2.0
   iMessage Plugin                 Python version:                2.7.10 (default, Feb  7 2017, 00:08:15) [GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
   iMessage Plugin                 Python Directory:              /System/Library/Frameworks/Python.framework/Versions/2.7
   iMessage Plugin                 ==================================================================================================================================
   iMessage Plugin Debug           logLevel = 5
   Started plugin "iMessage Plugin 0.1.4"
   iMessage Plugin Debug           Starting Plugin. startup() method called.
   iMessage Plugin Debug           Adding Trigger Test iMessage Trigger (1978200985) - commandReceived
   iMessage Plugin Debug           ConnectSQL: Filename location for iMsg chat.db equals:/Users/brandonjones/Library/Messages/chat.db
   iMessage Plugin Debug           Connect to Database Successful.
   iMessage Plugin                 Connection to iMsg Database Successful.
   iMessage Plugin                 iMessage: Update Checking. Your Current version is: 0.1.4
   iMessage Plugin Debug           Current version is: 0.1.4
   iMessage Plugin Debug           Getting latest release from ghawken/iMessagePlugin...
   iMessage Plugin Debug           GET /repos/ghawken/iMessagePlugin/releases/latest
   iMessage Plugin Debug           HTTP Err result:  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100  2790  100  2790    0     0   8875      0 --:--:-- --:--:-- --:--:--  8857
   iMessage Plugin Debug           ReturnCode:0
   iMessage Plugin Debug           Json results:{u'body': u'# 0.4.0\r\n\r\n# Wit.Ai Processing {Optional}\r\n\r\n![](https://github.com/Ghawken/iMessagePlugin/blob/master/DocumentPics/icon.png?raw=true)\r\n\r\n## Changelog:\r\n\r\n## 0.4.0\r\n\r\nUpdates to Plugin Config to show current status of requests/Updates/Delete/Generate\r\nCorrectly shows new App Access_token/App_ID\r\nSome bug fixes to deal with app creation errors\r\nRename Wit.Ai App to username+Indigo-iMessage (to allow multiple wit.ai apps for multiple Indigo installs, with one wit.ai access code only) (side-effect - makes development easier!)\r\nAs Plugin accesses app via Access_code only and not name, new name will only happen with deletion/creation of current app. 0.4.0 - Bug fix for this.\r\nLog Current Status in Menu - updates - useful for bug checking\r\nBeta: Device_Status intent - can ask \r\n"What is the status of {device_name}?"  \r\nAutomatically Updates wit.ai App when new version Plugin Installed\r\n\r\n', u'assets_url': u'https://api.github.com/repos/Ghawken/iMessagePlugin/releases/14547941/assets', u'name': u'0.4.0', u'published_at': u'2018-12-14T22:21:13Z', u'author': {u'following_url': u'https://api.github.com/users/Ghawken/following{/other_user}', u'events_url': u'https://api.github.com/users/Ghawken/events{/privacy}', u'avatar_url': u'https://avatars2.githubusercontent.com/u/6187293?v=4', u'url': u'https://api.github.com/users/Ghawken', u'gists_url': u'https://api.github.com/users/Ghawken/gists{/gist_id}', u'html_url': u'https://github.com/Ghawken', u'subscriptions_url': u'https://api.github.com/users/Ghawken/subscriptions', u'node_id': u'MDQ6VXNlcjYxODcyOTM=', u'repos_url': u'https://api.github.com/users/Ghawken/repos', u'received_events_url': u'https://api.github.com/users/Ghawken/received_events', u'gravatar_id': u'', u'starred_url': u'https://api.github.com/users/Ghawken/starred{/owner}{/repo}', u'site_admin': False, u'login': u'Ghawken', u'type': u'User', u'id': 6187293, u'followers_url': u'https://api.github.com/users/Ghawken/followers', u'organizations_url': u'https://api.github.com/users/Ghawken/orgs'}, u'url': u'https://api.github.com/repos/Ghawken/iMessagePlugin/releases/14547941', u'created_at': u'2018-12-14T21:58:26Z', u'target_commitish': u'wit.ai', u'tarball_url': u'https://api.github.com/repos/Ghawken/iMessagePlugin/tarball/0.4.0', u'html_url': u'https://github.com/Ghawken/iMessagePlugin/releases/tag/0.4.0', u'zipball_url': u'https://api.github.com/repos/Ghawken/iMessagePlugin/zipball/0.4.0', u'tag_name': u'0.4.0', u'node_id': u'MDc6UmVsZWFzZTE0NTQ3OTQx', u'draft': False, u'prerelease': False, u'upload_url': u'https://uploads.github.com/repos/Ghawken/iMessagePlugin/releases/14547941/assets{?name,label}', u'id': 14547941, u'assets': []}
   iMessage Plugin Debug           Latest release is: 0.4.0
   iMessage Plugin                 iMessage: Update Checking. The Github Latest release is: 0.4.0
   iMessage Plugin                 iMessage: Update Checking. Please visit the Plugin Store to Download
   iMessage Plugin Error           iMessage: Update Checking.  Update is Available.  Please check Store for details/download.
Sat Jan 19, 2019 2:43 pm
GlennNZ offline
Thanks.
Can you either post or PM me the same debug log (with all debug options on)when you receive a message?
Glenn
Sat Jan 19, 2019 7:45 pm
bjones offline
That's actually the issue -- when I send to my indigo iMessage userI don't get any sort of log for a new message received, but it is of course received in iMessage.
Thanks.
Glenn
Sat Jan 19, 2019 8:44 pm
GlennNZ offline
Hmm
Even with all the debug options on?
Check the Plugins/Imessage Plugin/Show Current Status menu & post
PM me a long debug long with a few incoming messages - with all debug options on.
The log will be in
"Show Event Logs Folder" - from Log Window
/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.GlennNZ.indigoplugin.iMessage/plugin.log
G
Sun Jan 20, 2019 9:17 am
bjones offline
PM Sent!
GlennNZ wrote:
Hmm
The log will be in
G
Sun Jan 20, 2019 9:38 pm
GlennNZ offline
Hi all,
To follow this up - turns out that apple changed the date time format they were using between Sierra and High Sierra and above. It appears they always used a from 2001-01-01 custom UTC date time, with Mojave using Nanoseconds...
This was the problem above which with the help of bjones we tracked down in record time.
Have a new version 0.4.1 on github wit.ai branch fixing the issue for those on Sierra and below.
https://github.com/Ghawken/iMessagePlugin/tree/wit.ai
Those on Sierra and below will likely need to update their folder permissions for the iMessage Database, located here:
~/Library/Messages
Glenn
Wed May 22, 2019 2:18 pm
whmoorejr offline
~/Library/Messages
That resolved the error message I was getting when receiving messages. I've only been using the plugin for about 5 hours now... but loving every minute of it.
