Qubino ZMNHJD1 Pilot Wire module
Forum rules
Sat Oct 27, 2018 5:19 am
bento offline
Hello,
Over here most of the electric heaters are compatible with pilot wire control.
Thus I just bought online Qubino ZMNHJD1 Pilot Wire module that should do the job.
However I realize now that this module might not be compatible with Indigo..
Any thought ? If not yet compatible would it be something easy to do ?
Here is a link toward the user manual : https://www.vesternet.com/mwdownloads/download/link/id/1382/product/2314/z_wave_qubino_flush_module_pilot_wire_zmnhjd1_plus_uuser_manual_v1_1.pdf
Zwave command supported are displayed on the second page.
Anyone else here using pilot wire over Zwave ?
Thanks a lot
Sat Oct 27, 2018 12:36 pm
Re: Qubino ZMNHJD1 Pilot Wire module
I'm not familiar with that module. After syncing it with Indigo, what types of devices does Indigo create? Re-sync it and copy/paste the Event Log results so we can see some more details on how Indigo is handling it.
Note even though Indigo doesn't have a device definition for the module you can still adjust all of the configuration parameters for it via the Interfaces->Z-Wave->Modify Configuration Parameter... menu item. You'll just need to reference the manual you linked to for what the parameters do.
Sat Oct 27, 2018 12:41 pm
bento offline
I should receive the device some time next week. I will let you know about the result.
Thu Nov 01, 2018 2:08 pm
bento offline
Module received and installed. It shows up as a dimmable switch. The heater mode is set according to the dimmable value.
It works fine just as it is.
Thu Nov 01, 2018 3:32 pm
DomoPat offline
Sorry I did not see your post last week, I have a couple of these and they work fine as you already found out... one of them is also connected to a "delesteur" and switches one zone OFF when the "delesteur" is overloaded: so I get automatic and Indigo control on the pilot wires which is nice !
Users browsing this forum: Different Computers and 0 guests
