GE outlet (Z-Wave Plus) - 14288
Forum rules
Wed Oct 17, 2018 8:39 pm
lanbrown offline
This device works fine in Indigo and it only has a single configurable option which is the change when the light is on.
https://byjasco.com/sites/default/files/product/manuals/14288%20QSG%20v1.pdf
Available Configuration Parameters
LED Light
Parameter No: 3
Length = 1 byte
Possible values = 0, 1 (default) or 2
Value desciptions
“0” - LED ON when Load is OFF, LED OFF when load is ON
“1” - LED ON when Load is ON, LED OFF when load is OFF
“2” - LED always OFF
Anyway just to add that to the profile for the device like some Aeotec and Enerwave products can be figured?
Thu Oct 18, 2018 3:54 pm
Re: GE outlet (Z-Wave Plus) - 14288
Have you submitted the device info using the Submit Device Information button in the config dialog? If it shows up, please fill out the form that it takes you to. If the Submit Device Information button isn't there, then click the Write Device Details to Event Log button and copy/paste the results from the event log into a reply.
In the meantime, you can of course adjust that config parameter using the Interfaces->Z-Wave->Modify Config Parameter... menu item.
Thu Oct 18, 2018 4:57 pm
lanbrown offline
I may have submitted it in the past but I'll do it again.
I have it set how I want, but just clicking on the device settings to make changes is far easier.
Fri Oct 19, 2018 9:38 am
Go ahead and do the Write Device Information to Log and copy/paste it here. It might be in our DB already, but without knowing the exact Z-Wave manufacturer/model information (that's not the model number in the subject line) it's hard to tell (GE has a TON of different model numbers).
Fri Oct 19, 2018 3:42 pm
lanbrown offline
Here you are:
Indigo Z-Wave Version: 2.0.119
Node ID: 37
Model: Relay Power Switch
Model ID: 49523133
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 4.38
Application Version: 5.23
Model Definition Version: 0
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 27v1 2Bv1 2Cv1 70v1 72v1 73v1 56v1 59v1 5Av1 7Av1 5Ev1 25v1
Features: routing, beaming
Neighbors: 11, 12, 13, 14, 16, 17, 21, 22, 23, 24, 25, 28, 29, 30, 36, 44, 45, 50, 55
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Sat Oct 20, 2018 1:44 pm
Found it. The person that submitted it failed to include a link to it's docs which is required to get params added. I've made a note of the link you provided.
Sat Oct 20, 2018 1:45 pm
lanbrown offline
Thank you.
