how to use SSH to send any command to a unix box
put this into action/ server script
##### put me into an action  action window/server/execute script
import subprocess
userID         = "the userid on the unixbox"
password       = "the password on the unix box"
ipNumber       = "192.168.1.xxx"
promptOnServer = "the prompt on the unix box eg @"
cmd            = "ls -l"  ## the command you like to send
file           = "/users/your-mac-id-here/documents/ssh.cmd"
f=open(file,"w")
f.write('spawn  ssh '+userID+'@'+ipNumber+'\n'
   +'set timeout 10\n'
   +'   expect {\n'
   +'   "(yes/no)?" {\n'
   +'   send "yes\\n"\n'
   +'   sleep 0.1\n'
   +'   expect "assword" { send "'+password+'\\n"}\n'
   +'      }\n'
   +'      "assword: " {\n'
   +'          send "'+password+'\\n"\n'
   +'      }\n'
   +'}\n'
   +'expect '+ promptOnServer+'\n'
   +'sleep 0.1\n'
   +'send "'+cmd+' \\n"\n'
   +'sleep 0.1\n'
   +'sleep 0.1\n'
   +'send "exit\\n"\n'
   +'expect eof\n'
f.close()
###### either
## if you want to wait for the result:
ret = subprocess.Popen("/usr/bin/expect "+ file, stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True).communicate()
indigo.server.log(unicode(ret))
###### or
## if it takes to long ( > 10 secs)  just add   & to the end
## subprocess.Popen("/usr/bin/expect "+ file+" &", stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
hope some might find this useful
mundmc
Re: how to use SSH to send any command to a unix box
Post by mundmc »
Thanks Karl, This looks incredibly powerful.
mundmc
Post by mundmc »
Karl,
I finally tried to play with this on a raspi on Debian linux. Will this strictly only work on Unix? I am seeing the login info from the raspi, but it is then timing out. I am trying to tell firefox on a remote pi to open a window using a command that works from ssh.
Edit: I changed "assword" to "password".
Leave assword. As sometimes it is Password and sometimes password
Which Unix. It depends on the prompts
It will not work on windows.
expect -D ...
or -d
'that gives you a trace
do
man expect
on the unix prompt
for everything you always wanted to know
and expect has to run on the host from where you launch it.- does not need to be available on the target .. = does not use it
mundmc
Post by mundmc »
kw123 wrote:Leave assword. As sometimes it is Password and sometimes password
Lol, assword it is!
MunDMC
Fitter. Happier. More productive.
mundmc
Post by mundmc »
kw123 wrote:try:
expect -D ...
or -d
do
man expect
on the unix prompt
I’m sorry, Karl, but in reference to the lines above, am i putting them into the script (and, if so, where)?
MunDMC
Open a terminal on your mac
man expect
q to exit
expect -d your script name here
to get the full debug into the logfile from within indigo action:
import subprocess
f=open(file,"w")
   +'set timeout 10\n'
   +'   expect {\n'
   +'   "(yes/no)?" {\n'
   +'   send "yes\\n"\n'
   +'   sleep 0.1\n'
   +'      }\n'
   +'      "assword: " {\n'
   +'      }\n'
   +'}\n'
   +'sleep 0.1\n'
   +'sleep 0.1\n'
   +'sleep 0.1\n'
   +'send "exit\\n"\n'
   +'expect eof\n'
f.close()
ret = subprocess.Popen("/usr/bin/expect -d "+ file, stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True).communicate()
add >> -d  << with the spaces
lower case d not D
you should then see:
[code]MacPro-2012:~ karlwachs$ /usr/bin/expect -d '....
argv[0] = /usr/bin/expect  argv[1] = -d  argv[2] = ...
set argc 8
set argv0 "...
set argv ...
executing commands from command file ....
spawn sftp -o ConnectTimeout=15 [email protected]
parent: waiting for sync byte
parent: telling child to go ahead
parent: now unsynchronized from child
spawn: returns {35747}
expect: does "" (spawn_id exp6) match glob pattern "(yes/no)? "? no
"assword"? no
[email protected]'s password:
expect: does "[email protected]'s password: " (spawn_id exp6) match glob pattern "(yes/no)? "? no
"assword"? yes
expect: set expect_out(0,string) "assword"
expect: set expect_out(spawn_id) "exp6"
expect: set expect_out(buffer) "[email protected]'s password"
send: sending "xxxxxx\r" to { exp6 }
... and many more lines
but w/o the line brakes instead you will see \n where the line breaks should be..
mundmc
Post by mundmc »
Karl you are my Indigo spirit totem animal.
MunDMC
Is there an emoji for that?
mundmc
Post by mundmc »
kw123 wrote:Is there an emoji for that?
