Some questions to the validation process )
What's wrong here?
address : 4
batteryLevel : None
buttonGroupCount : 0
configured : True
coolIsOn : False
coolSetpoint : 8.0
dehumidifierIsOn : False
description :
deviceTypeId : zwThermostatType
displayStateId : temperatureInputsAll
displayStateImageSel : HvacHeatMode
displayStateValRaw : 23.3
displayStateValUi : 23.3
enabled : True
energyAccumBaseTime : 2019-03-12 19:41:57
energyAccumTimeDelta : 7945475
energyAccumTotal : 0.0
energyCurLevel : 5.4
errorState :
fanIsOn : False
fanMode : AlwaysOn
folderId : 833704369
com.perceptiveautomation.indigoplugin.zwave : (dict)
NumHumidityInputs : 1 (integer)
ShowCoolHeatEquipmentStateUI : false (bool)
SupportsBatteryLevel : false (bool)
SupportsEnergyMeter : true (bool)
SupportsEnergyMeterCurPower : true (bool)
SupportsEnergyMeterReset : true (bool)
SupportsGasMeterReset : true (bool)
SupportsOnState : false (bool)
SupportsSensorValue : false (bool)
SupportsStatusRequest : true (bool)
SupportsWaterMeterReset : true (bool)
TempUnits : 1 (integer)
address : 4 (integer)
indigoObjVersion : 8 (integer)
modelNameAndFirmware : General Thermostat (v2), firmware 1.01 (string)
propsPushTickler : 2 (string)
tempAlwaysFalse : false (bool)
userPollAfterActivity : true (bool)
userPollInterval : 10 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 60 (integer)
version : 1.01 (string)
zwAppVersMajor : 1 (integer)
zwAppVersMinor : 1 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
g3 : (list)
g4 : (list)
g5 : (list)
g6 : (list)
g7 : (list)
g8 : (list)
g9 : (list)
zwAssociationsMapStr : 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[] 7:[] 8:[] 9:[] (string)
zwClassCmdBase : 64 (integer)
zwClassCmdMap : (dict)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c142 : 1 (integer)
c32 : 1 (integer)
c39 : 1 (integer)
c49 : 7 (integer)
c50 : 4 (integer)
c64 : 1 (integer)
c67 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c94 : 1 (integer)
zwClassCmdMapStr : 20v1 40v1 43v1 85v1 86v1 27v1 32v4 8Ev1 70v1 31v7 72v1 73v1 59v1 5Av1 5Ev1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 8 (integer)
Item : 6 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : General Thermostat (v2) (string)
zwConfigVals : (dict)
zwConfigValsStr : - none - (string)
zwDevSubIndex : 0 (integer)
zwEncryptClassCmdMap : (dict)
zwEncryptClassCmdMapStr : - none - (string)
zwEncryptionStatusStr : Not Supported (string)
zwEndpointClassMap : (dict)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMap : (dict)
zwEndpointDevTypeMapStr : - none - (string)
zwFeatureListStr : routing, beaming, energyMeter (string)
zwLibType : 3 (integer)
zwManufactureId : 345 (integer)
zwManufactureName : Qubino (string)
zwMeterSubTypeFlags : 5 (integer)
zwMeterSupportsReset : true (bool)
zwMeterType : 1 (integer)
zwModelDefnVers : 0 (integer)
zwModelId : 327763 (integer)
zwModelName : General Thermostat (v2) (string)
zwNodeNeighbors : (list)
Item : 3 (integer)
Item : 9 (integer)
Item : 19 (integer)
Item : 20 (integer)
Item : 21 (integer)
Item : 24 (integer)
Item : 29 (integer)
Item : 30 (integer)
Item : 39 (integer)
Item : 40 (integer)
Item : 46 (integer)
Item : 49 (integer)
Item : 54 (integer)
Item : 56 (integer)
Item : 57 (integer)
Item : 59 (integer)
Item : 60 (integer)
Item : 61 (integer)
Item : 64 (integer)
Item : 66 (integer)
Item : 67 (integer)
Item : 71 (integer)
Item : 74 (integer)
Item : 76 (integer)
Item : 85 (integer)
Item : 88 (integer)
Item : 91 (integer)
Item : 93 (integer)
Item : 98 (integer)
Item : 100 (integer)
Item : 104 (integer)
Item : 108 (integer)
Item : 111 (integer)
Item : 115 (integer)
Item : 122 (integer)
Item : 123 (integer)
Item : 124 (integer)
Item : 126 (integer)
Item : 127 (integer)
Item : 130 (integer)
Item : 141 (integer)
Item : 148 (integer)
Item : 150 (integer)
Item : 151 (integer)
Item : 159 (integer)
Item : 169 (integer)
Item : 174 (integer)
Item : 175 (integer)
Item : 178 (integer)
Item : 181 (integer)
Item : 182 (integer)
Item : 187 (integer)
Item : 189 (integer)
Item : 196 (integer)
Item : 201 (integer)
Item : 204 (integer)
Item : 219 (integer)
Item : 222 (integer)
Item : 227 (integer)
Item : 232 (integer)
zwNodeNeighborsStr : 3, 9, 19, 20, 21, 24, 29, 30, 39, 40, 46, 49, 54, 56, 57, 59, 60, 61, 64, 66, 67, 71, 74, 76, 85, 88, 91, 93, 98, 100, 104, 108, 111, 115, 122, 123, 124, 126, 127, 130, 141, 148, 150, 151, 159, 169, 174, 175, 178, 181, 182, 187, 189, 196, 201, 204, 219, 222, 227, 232 (string)
zwProtoVersMajor : 4 (integer)
zwProtoVersMinor : 5 (integer)
zwShowDumpDevToLog : false (bool)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : true (bool)
zwShowPollingUI : true (bool)
zwShowSubmitModelInfoUI : true (bool)
zwShowWakeIntervalUI : false (bool)
zwWakeInterval : 0 (integer)
heatIsOn : False
heatSetpoint : 8.0
humidities : [29.0]
humiditySensorCount : 1
hvacMode : Heat
lastChanged : 2019-10-28 11:02:48
lastSuccessfulComm : 2019-10-28 11:02:48
model : General Thermostat (v2)
name : Kitchen Heated Floor Thermostat
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
g3 : (list)
g4 : (list)
g5 : (list)
g6 : (list)
g7 : (list)
g8 : (list)
g9 : (list)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c142 : 1 (integer)
c32 : 1 (integer)
c39 : 1 (integer)
c49 : 7 (integer)
c50 : 4 (integer)
c64 : 1 (integer)
c67 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c94 : 1 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 8 (integer)
Item : 6 (integer)
Item : 3 (integer)
Item : 9 (integer)
Item : 19 (integer)
Item : 20 (integer)
Item : 21 (integer)
Item : 24 (integer)
Item : 29 (integer)
Item : 30 (integer)
Item : 39 (integer)
Item : 40 (integer)
Item : 46 (integer)
Item : 49 (integer)
Item : 54 (integer)
Item : 56 (integer)
Item : 57 (integer)
Item : 59 (integer)
Item : 60 (integer)
Item : 61 (integer)
Item : 64 (integer)
Item : 66 (integer)
Item : 67 (integer)
Item : 71 (integer)
Item : 74 (integer)
Item : 76 (integer)
Item : 85 (integer)
Item : 88 (integer)
Item : 91 (integer)
Item : 93 (integer)
Item : 98 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
accumEnergyTimeDelta : 7945475 (integer)
accumEnergyTimeDelta.ui : 7945475 seconds (string)
accumEnergyTotal : 0 (real)
accumEnergyTotal.ui : 0.0 kWh (string)
curEnergyLevel : 5.4 (real)
curEnergyLevel.ui : 5.4 W (string)
humidityInput1 : 0 (integer)
humidityInputsAll : (string)
hvacFanMode : 1 (integer)
hvacFanMode.ui : always on (string)
hvacFanModeIsAlwaysOn : true (bool)
hvacFanModeIsAuto : false (bool)
hvacOperationMode : 1 (integer)
hvacOperationMode.ui : heat on (string)
hvacOperationModeIsAuto : false (bool)
hvacOperationModeIsCool : false (bool)
hvacOperationModeIsHeat : true (bool)
hvacOperationModeIsOff : false (bool)
hvacOperationModeIsProgramAuto : false (bool)
hvacOperationModeIsProgramCool : false (bool)
hvacOperationModeIsProgramHeat : false (bool)
setpointCool : 8 (real)
setpointCool.ui : 8.0 °C (string)
setpointHeat : 8 (real)
setpointHeat.ui : 8.0 °C (string)
temperatureInput1 : 23.3 (real)
temperatureInput1.ui : 23.3 °C (string)
temperatureInputsAll : 23.3 (string)
zwaveHvacOperationModeID : 1 (integer)
zwaveHvacOperationModeName : heat (string)
subModel :
supportsAllOff : False
supportsCoolSetpoint : True
supportsHeatSetpoint : True
supportsHvacFanMode : True
supportsHvacOperationMode : True
supportsStatusRequest : True
temperatureSensorCount : 1
temperatures : [23.3]
version : 1.01
shapa wrote:It looks like you removed my kitchen thermostat support from the latest versions as well
Could you please add it back? ...
shapa wrote:Some questions to the validation process )
What's wrong here?
autolog wrote:shapa wrote:It looks like you removed my kitchen thermostat support from the latest versions as well
If I did it wasn't intentional - I will take a look at it now.
Busta999 wrote:Autolog - just a heads up of a weird issue that has come up twice in 24 hrs.
I have changed the set point for the Day schedule to 20.5 for the Lounge Front and Back TRVs.
The Back TRV reported the Remote Temp (SRT321) as 23.5C and the set point as 25.5C.
And driving the central heating hard to get the Lounge to 25.5C.
Restarting the TRV Plugin reset the Lounge Back to 20.5C SetPoint and immediately turned off heating.
This occurred yesterday afternoon when I changed the SetPoint to 20.5 and again this morning when the Day Schedule started.
Both TRVs are Spirits. Front .15 and Back .16 firmware (maybe significant ?)
Indigo 7.4 TRV Plugin 1.3.1 on Mac OS 10.12.6
I have now set both Front and Back to 20C for Day Schedule - and will keep a closer eye on it.
Busta999 wrote:Maybe significant - Over the weekend despite the Back TRV reporting valve open 100% and Remote Temp Below Setpoint and the Front TRV was Open and radiator hot the Back radiator was cold. Obviously the valve was actually shut. The battery was reporting 35% but just in case I swapped out the batteries and the valve opened and the radiator got hot immediately.
It maybe unrelated, it maybe a faulty Spirit. I'll keep a better eye on it.
I'll report back with more details if it occurs again.
When you reload the plugin it will set the schedules back to the plugin default as defined for each TRV Controller device. Did you rerun the action to set the Day Schedules again?
Having the TRV On/Off setting enabled may help.
Busta999 wrote:When you reload the plugin it will set the schedules back to the plugin default as defined for each TRV Controller device. Did you rerun the action to set the Day Schedules again?
Nope just as Plugin Reload.
autolog wrote:I am still confused(easily done)
Busta999 wrote:autolog wrote:I am still confused(easily done)
It’s our age
Busta999 wrote:autolog wrote:I don't understand what the problem is? If you alter the setpoint of a TRV Controller and then reload the plugin, it will reset the setpoint to whatever schedule is currently active.
Did this not happen?
The problem was
Whilst in normal running the TRV changed the set point to 5c above the target in the schedule, ie targeted at 20.5 but had an actual set point of 25.5c while the remote temp sensor was reporting 23.5c.
The TRV was keeping the heating on so the lounge was getting very hot
To fix the immediate problem I reloaded the TRV plugin.
That restored the TRV to the correct set point and accordingly shut down the heating.
Hopefully explained it better ?
