Indigo 7.2 Release Notes
Fri Sep 28, 2018 10:15 am
7.2.0 is now available for download (you must be logged in to your Indigo Account to download). For an overview of the changes in this version, see our blog announcement here.
Note: This is the first version that may not be available to all Indigo 7 users, specifically those who have allowed their Up-to-Date Subscription to lapse. The downloads page will show if you are eligible for the latest release or you can also check the licenses page in your Indigo Account or use the Indigo 7->License Details... menu to see the status of your subscription.
Maintenance releases of Indigo 7.2 (7.2.1, etc) are outlined below this post on this forum topic.
First, a note on App and path names: we've changed things up so it's easier for users to switch back to a previous version if they like. For this release, we've changed the install path to:
/Library/Application Support/Perceptive Automation/Indigo 7.2/
The installer is smarter than it used to be and now moves control page images over for you (among other improvements). The other change is that the Indigo Mac Client app is now named:
/Applications/Indigo 7.2
We've added the full feature version number into the name to make it easier to identify which client you're trying to launch. If you have problems upgrading from a previous version of Indigo then read through the documentation here for some tips.
New General Features and Fixes
  • Added a new Execute Conditional Actions button to the detail area of Triggers and Schedules that will first evaluate the conditions to determine if the actions should execute. The other button has been renamed Execute Actions Only to emphasize that it does not evaluate conditions.
  • Added the Show Dependencies item to the contextual menu when you right-click an Action Group in the Action Group list.
  • Added the delay settings to the actions list description in an Action Group if there is a delay set so it's easier to see the delays on multiple actions in one view.
  • Added status icons in the Plugins menu to indicate (at a glance) if the plugin is enabled or disabled.
  • Added ability to search using ID of Devices, Triggers, Schedules, Action Groups, Control Pages, and Variables in the Main Window UI.
  • Added Brand Specific actions submenu (Device Actions->Brand Specific Controls) for actions that are specific to a brand or manufacturer (HomeSeer / Insteon / etc).
  • Added HomeSeer WS200+/WD200+ specific actions to control the color, status, and color of the LEDs.
  • Added action to reload a plugin (Server Actions->Enable/Disable/Reload Actions->Reload Plugin). Plugin IDs may now be found on the plugin's detail page in the Plugin Store.
  • Added workaround for Viasat (used to be Exede) satellite ISP's unreported blocking of a crucial Indigo reflector port via a port selection menu control in the Start Local Server dialog..
  • Improved performance of Plugins.
  • Fixed bug that caused the Indigo Account authentication dialog to erronously show after the daylight-saving-time adjustment.
  • Fixed bug that could cause parts of the Indigo Client UI to be out-of-sync with the server when switching between multiple Indigo Servers.
  • Fixed popup control file name sorting problem for Control Page images.
New Z-Wave Devices and Fixes
  • Added Z-Wave support for Aeotec Multi-Color LED Bulb 6 (ZWA002).
  • Added Z-Wave support for Aeotec Multi-White LED Bulb 6 (ZWA001).
  • Added Z-Wave support for Aeotec NanoMote One (ZWA004).
  • Added Z-Wave support for Aeotec NanoMote Quad (ZWA003).
  • Added Z-Wave support for Aeotec TriSensor (ZWA005).
  • Added Z-Wave support for August Home Smart Lock Pro.
  • Added Z-Wave support for Black Cat Double Relay Module (ZWBCL2).
  • Added Z-Wave support for Danalock V3 (BTZE).
  • Added Z-Wave support for Devolo Key Fob (09814).
  • Added Z-Wave support for Devolo Multi Sensor (02648).
  • Added Z-Wave support for Devolo Scene Switch (MT:2652).
  • Added Z-Wave support for Devolo Smoke Alarm (09358).
  • Added Z-Wave support for Dome Door/Window Sensor (Standard and Pro).
  • Added Z-Wave support for Dome On/Off Plug-In Switch.
  • Added Z-Wave support for Dome Water Main Shutoff.
  • Added Z-Wave support for Dome Water Sensor (DMWS1).
  • Added Z-Wave support for Ecolink Door/Window Sensor (DWZWAVE2.5-ECO).
  • Added Z-Wave support for Enerwave Smart Wall Outlet (ZW15RM-PLUS).
  • Added Z-Wave support for EUROtronic Thermostat (Spirit).
  • Added Z-Wave support for Evolve Remote Dimmer Switch (LTM-5).
  • Added Z-Wave support for new variant of Fibaro Door/Window Sensor 2 (FGDW002).
  • Added Z-Wave support for new variant of Fibaro Leak Sensor (FGFS101).
  • Added Z-Wave support for Heiman Smart Plug (HS2SK-Z).
  • Added Z-Wave support for HomeSeer Switches (HS-WD200+ and HS-WS200+)
  • Added Z-Wave support for Horstmann Secure Countdown Timer (SIR321).
  • Added Z-Wave support for Horstmann Water Meter (SWM301).
  • Added Z-Wave support for Inovelli Dual Smart Plug.
  • Added Z-Wave support for Inovelli Power Strip (ZEN20).
  • Added Z-Wave support for Inovelli Relay Switch (ZEN21).
  • Added Z-Wave support for KAS Keypad Door Lock (KAS-600).
  • Added Z-Wave support for MCOHome Air Quality Monitor PM2.5 (MH10).
  • Added Z-Wave support for MCOHome CO2 Monitor (MH9-CO2).
  • Added Z-Wave support for MonoPrice Door/Window Sensor (24259).
  • Added Z-Wave support for MonoPrice Smart Plug (HKZW-SO03).
  • Added Z-Wave support for Neo CoolCam Power Plug (NAS-WR02ZU)
  • Added Z-Wave support for new variant of Neo CoolCam Motion Sensor (NAS-PD02Z).
  • Added Z-Wave support for Nexia Doorbell Sensor (DB100Z).
  • Added Z-Wave support for Philio Motion Sensor (PSP05).
  • Added Z-Wave support for Philio Multi Sensor (PAT02-A and PAT02-C).
  • Added Z-Wave support for Popp CO Detector (004407).
  • Added Z-Wave support for Qubino Din Dimmer (ZMNHSD).
  • Added Z-Wave support for TKBHome Smart Energy Appliance Module (TZ69E).
  • Added Z-Wave support for Zipato Multisensor Quad (OEM of Philio PST02 sensors).
  • Added Z-Wave support for Zooz and Inovelli Dimmer Switch (ZEN22).
  • Added Z-Wave support for Zooz Smart Plug (ZEN06).
  • Added Z-Wave support for Zooz Mini Plug (ZEN07).
  • Added Z-Wave support for Zooz Power Switch (ZEN15).
  • Added Z-Wave support for Zooz Motion / Light Sensor (ZSE09).
  • Added Z-Wave support for new variant of 2GIG Thermostat (CT100).
  • Added Z-Wave support temperature sensor units configuration changing (Celsius / Fahrenheit) on the Aeotec Multi Sensor 6 (ZW100).
  • Added several new Z-Wave sensor unit labels, including ppm for Carbon Monoxide detectors.
  • Added new device states to capture Z-Wave thermostat mode commands: zwaveHvacOperationModeID, zwaveHvacOperationModeName.
  • Corrected Aeotec Nano Dimmer (ZW111) UI options for configuration parameters S1/S2 Switch Mode.
  • Corrected Qubino Flush Micro Dimmer (ZMNHDA and ZMNHDD) definition to fix problem setting some (#65 and #66) configuration parameters.
  • Fixed bug in Vision Door/Window Sensor (ZD2102+) configuration UI so that External Switch Broadcasting can be enabled.
  • Modified Z-Wave energy (kWh) states to allow for negative values (useful for solar/wind systems).
New Insteon Device Features
  • Added support for default ON level and ramp rate UI settings for Insteon PAR 38 LED Bulb (2674) and 8 Watt LED Bulb (2672). Re-Define/Sync your LED Bulb devices for the new UI to appear.
  • Added the ability to specify 0 for the LED brightness on Insteon devices. Note that it will only work for newer devices - older ones won't allow you to completely turn off the LEDs.
  • Added the ability to set the motion timeout for the Insteon Motion Sensor II (2844).
  • Added Insteon support for new variant of Insteon EZX10RF module.
Plugin Changes
  • SQL Logger Plugin: added the ability to filter errors in Event Log events by specifying text or regular expression for each error type.
  • WeatherSnoop Plugin (v3.0.0): added support for the API changes in WeatherSnoop 4, migrated the ID of the plugin so that development can be turned over to the WeatherSnoop team.
API Changes
  • Fixed deviceFilter bug in plugin actions that would require you to restart the Mac Client whenever you removed a deviceFilter from a plugin action. Just a reload will now work.
  • Added Example Variable Change Subscribe plugin to the SDK that illustrates how to monitor variable changes.
