Unwanted interaction with smoke alarms?
Thu Aug 23, 2018 5:20 am
Paul Chernoff offline
I have 5 wired smoke alarms (Kidde PI2010), when 1 goes off they all go off. They have been going off, usually 2 sets of 3 beeps, some evenings for the past few weeks. I would check the house, no problems, and the alarms will stay quiet for at least 24 hours. I think I figured out the problem last night but I would like your opinions.
I use X10 and Insteon technology to control the lights in my house, they send signals on the house's electrical lines. It occurred to me last night when the smoke alarms go off erroneously the smart home controller is sending a signal to turn off a light in the house. Is it possible that the signal on the electrical line is being interpreted by the smoke alarms to mean that another alarm has detected smoke? This is strange because I have had the alarms for 2 years and the other technology for 6 months and this problem is only a few weeks old.
Has anyone had this problem? If so, any solutions? I am deactivating light turnoff actions in Indigo for now and sending the turnoff commands via my iPhone for now. This way I will not get waken up at 2am. If I go a week with no incident I will reactivate the activities related to turning off the lights. I will first test the 3 X-10 devices and then the Indigo devices in case the signal used by one technology causes the problem and not the other.
Thu Aug 23, 2018 5:59 am
Re: Unwanted interaction with smoke alarms?
I'm by no means an expert, but my understanding of these systems would suggest that this wouldn't be the case. The systems I've seen (which is admittedly limited) have three conductors that go to each alarm. Two are for power and one is a signal wire. The signal wire is what's used to send messages between the alarms and would be electrically isolated from the power line. It might be possible that dirty power is making one of the alarms unhappy, but the ones I've seen shouldn't interpret that as an alarm state.
That said, these electronic doohickies sometimes do things they're not supposed to do. :D
EDIT: Forgot about ground. :oops:
Fri Aug 24, 2018 7:31 am
Thank you for the replies. Only the last time it went off did I think to check the Indigo logs, and there were 3 separate tasks that turned off switches (both X-10 and Insteon) at the same time. But when I look back the alarms had gone off at times when lights would automatically get turned off. The turn-off times are semi-randomized so I can't say for certainty if the alarms match the Indigo actions, but they roughly correspond.
I am currently deactivated the turn off switch command from Indigo and sending turn-off manually from my iPhone. I will do this for a week and see if the alarms go off on their own. Since I cannot make the alarm go off by command this will take some time, giving every test one week.
The scenario that an alarm has gone bad is possible. Since this problem is erratic it could take weeks of testing to determine if an alarm might be bad.
Thanks for the info on the recall, I will . While these alarms are only 2 years old I would like to replace them. The alarms have limited value because they all go off, I have no idea which alarm has detected smoke. Pretty worthless when you have a basement and two floors, plus I might add an alarm to my attic. I will check with Kidde and perhaps they will replace all of the alarms due to the recall.
Fri Aug 24, 2018 11:04 pm
RogueProeliator offline
FWIW, we have had terrible luck with both the FirstAlert and Kiddie smoke alarms -- false alarms all the time, and not just on one or two particular units.
The suggestion to look at the attic ones is very good -- of our failures, about 1/3 or 1/2 were caused by the attic detectors. Our electrician had wired those in with great intentions, but the detectors specifically say not to put them up there. Ended up taking several out; heat detectors (not affected by the dust/spiders/insulation/whatever) are fine for the area.
I probably will rip all the in-house ones out and replace with Nest Protects -- from my research they have EXCELLENT nuisance alarm avoidance compared to the others. But $$$... have to save up to do that project!
