mundmc wrote:Knowing very little about your use case, I can tell you I run a fairly flexible system as follows. But please note, if I were to buy it again, I’d go Unifi cams and NVR (and plugin).
-Amcrest NVR
-Power over Ethernet switch (to keep camera traffic to NVR locally on that switch as much as possible)
-4 PTZ cams inside, 4 outdoor cams, all Amcrest (if you need it, I can find the model numbers, but they are the cheapest they made, because I don’t need crazy HD resolution)
-Security Spy on server Mac (because it is easier and more functional than scripting for the NVR as a source)
Vig wrote:Just curious, why do you use Amcrest NVR if you already have SecuritySpy?
Are there any plug-ins that work with certain appliance NVRs?
