Insteon Command Received - Status Changed Broadcast
Sun Aug 05, 2018 3:31 pm
jordanrounds offline
I'm trying to simply update a variable to true when I get a status changed broadcast from an Intsteon dimmer. The Trigger will never get hit for some reason.
Screen Shot 2018-08-05 at 2.29.03 PM.png (283.58 KiB) Viewed 3142 times
Sun Aug 05, 2018 4:31 pm
Re: Insteon Command Received - Status Changed Broadcast
Try the "Any Command" option from the Received popup.
Sun Aug 05, 2018 5:59 pm
Any Command does not work either. I've tried this with multiple Insteon switches with the same result. Ive tried hitting the trigger as well as pushing the switch manually.
Sun Aug 05, 2018 6:29 pm
Do you have any Conditional set? Also, copy/paste what occurs in the Event Log as you press the button (when you would expect the Trigger to fire) into a reply for me.
Mon Aug 06, 2018 8:45 pm
I dont have any conditions set. Here is the log:
   Received INSTEON                "Back Patio Light Switch" off
   Received INSTEON                "Back Patio Light Switch" on
Mon Aug 06, 2018 9:00 pm
I had forgotten this, but Status Changed Broadcast isn't sent by Insteon dimmers or switches. It is only used by some more complex modules (like irrigation controllers).
However, Any Command should definitely work. I just tried that one here with an Insteon Dimmer and the Trigger consistently fired after every button press release.
   Received INSTEON                "hallway light (downstairs)" on
   Trigger                         Any Command Test
   Received INSTEON                "hallway light (downstairs)" off
   Received INSTEON                "hallway light (downstairs)" start brighten
   Received INSTEON                "hallway light (downstairs)" stop brighten
   Sent INSTEON                    "hallway light (downstairs)" status request (received: 47)
Tue Aug 07, 2018 10:50 am
Thanks! Any command does work.
Tue Aug 07, 2018 10:55 am
What changed from when it wasn't working previously?
Mon Aug 20, 2018 12:20 pm
It was my bad. I was trying to trigger the switch on and off through indigo instead of just pushing it manually.
