Somfy/RTS control
Thu Aug 16, 2018 8:26 am
koburg offline
Re: Somfy/RTS control
this is from the rfplayer log
ZIA44 FRAME: frameType: 0, cluster: 0, dataFlag: 0,
rfLevel: -56dBm, floorNoise: -94dBm, rfQuality: 9
protocol: 9 (RTS), infoType: 3, frequency: 433920Khz
subType: 0 (Shutter), id: 3191872, qualifier: 4 ( My)
Thu Aug 16, 2018 8:28 am
koburg offline
tried also with qualifier 4 same error
RFPlayer Debug                  sendCommandAction command 'My rts ID 3191872 qualifier 0' to RF USB
   RFPlayer Debug                  json decode failure:
ZIA--
error request number=0
Syntax error: My rts ID 3191872 qualifier 0
Thu Aug 16, 2018 9:38 am
ZIA--
Wait. Are you trying to do that with the "send text command" action? Don't do that. There's a specific device action for the "My" command.
Screen Shot 2018-08-16 at 11.37.51 AM.png (531.76 KiB) Viewed 356 times
Thu Aug 16, 2018 9:40 am
koburg offline
yes I did that but it is sending an off command
not MY command so the blind just go all the way down
Thu Aug 16, 2018 9:47 am
The correct command is either "on rts ID 3191872 qualifier 4" or "off rts ID 3191872 qualifier 4". It's not clear from the docs. The "qualifier 4" is what triggers the "my" action.
Please try both of those, with logging on, and post here.
