Ye Old “Application isn’t running” Error
Fri Jul 20, 2018 8:10 pm
ckeyes888 offline
Just started getting the “Indigoserver got an error: Application isn’t running” error when executing an external
AS that calls the Indigo server. It’s triggered from an app I use to display CID info on incoming calls.
It’s the first time I’ve seen this error when running a script accessing Indigo on the same machine.
Accessing other apps using AS is working fine, it’s just the Indigoserver throwing the error.
Attached, I ran another script that should show what apps are seen to be running.
Maybe something to try to fix?
Carl
Sat Jul 21, 2018 8:53 am
Re: Ye Old “Application isn’t running” Error
Large topic on the issue. Bottom line, it's an OS bug(s) which we can't workaround and is a contributing factor to us deprecating AppleScript soon.
No idea what your script does, but you may be able to use the RESTful API or the Indigo basic applescript control script.
Sat Jul 21, 2018 2:33 pm
Sat Jul 21, 2018 6:37 pm
ckeyes888 offline
matt (support) wrote:
Ran that in Terminal and the AS works fine now.
Thanks, interesting to see how long the fix lasts.
Carl
