Steinel Z-Wave Lights
Wed May 16, 2018 7:06 am
petematheson offline
Hi All,
Bought one of these:
https://www.vesternet.com/z-wave-steine ... floodlight
I've added it to Indigo and I'm seeing 3 devices
Relay Switch for the main LED
Multilevel Sensor - Relay Power Switch which shows me nothing.
Notification Sensor - Relay Power Switch which shows me an on / off state, however this doesn't trigger when I walk past.
Any ideas on what the Multilevel sensor is (I think it's the light level sensor?) and how to get the Notification / motion sensor to work?
Steinel LED Flood
Standard 60w Bulb
Wed May 16, 2018 10:38 am
Re: Steinel Z-Wave Lights
That device will likely need a custom definition to work fully with Indigo's built-in stuff. It's possible that one of the Z-Wave plugins may be able to help in the meantime. Be sure to submit the device information so we can get it added to the list of device support requests.
Wed May 16, 2018 1:16 pm
Like this?
Z-Wave Indigo Device "Outdoor Garden Flood LED" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 81
Model: Relay Power Switch
Model ID: 00011A73
Manufacturer: Unknown
Manufacturer ID: 0271
Protocol Version: 4.38
Application Version: 0.48
Model Definition Version: 0
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 71v1 8Ev1 59v1 5Av1 5Ev1 60v4 22v1 25v1 27v1 2Bv1 2Cv1 70v1 31v4 72v1 73v1 77v1 7Av1
Multi-Endpoint Types: 1:(10 : 01), 2:(07 : 01), 3:(21 : 01)
Multi-Endpoint Classes: 1:[5E 85 8E 59 25 2B 2C 27 22], 2:[5E 85 8E 59 71], 3:[5E 31 85 8E 59]
Features: routing, beaming
Neighbors: - none -
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
Wed May 16, 2018 1:58 pm
By clicking the Submit Device Information button in the device's config dialog.
Wed May 16, 2018 4:49 pm
Done, thanks!
Have had to buy another one of these as they're a really great LED flood regardless of Z-wave, and we've had a near break in recently. So anything you could do to support to get the motion sensor working would be awesome :)
Thu May 17, 2018 1:14 am
Pete,
I think the motion sensor will work with Zwave Scene Controller plugin.
I recently updated it to support binary on/off commands from devices that are appearing on the market in this way.
I think I posted a beta link in the subforum for it.
Peter
Thu May 17, 2018 1:31 am
Thanks Peter, will check it out!
Thu May 17, 2018 3:13 pm
Hi Pete.
Just read the zwave doc for this device. Boy is it complex (and optionally multi-channel as well).
Can you set an association for groups 2, 3 and 4 to Node 1? Group 2 receives On/Off commands when the light is turned on due to motion, 3 is motion itself, group 4 is lux level.
With group 2 set, you should be able to use my plugin to receive the On/Off commands and trigger on them, until Matt/Jay release a definition - which won't be quick given how complex it is.
(M/J, at a basic level, it sends 0x71 notify (alarm v3+) commands of type 07 (Home security) and value 08 (motion) or 00 (no motion) - which is easy enough to trap, but it sends from different endpoints depending on state of params)
Peter
Sat May 19, 2018 4:26 pm
Thanks Peter, first time using your plugin and doing any manual associations.
Mind explaining how exactly I do the associations to Node 1?
Controlling Device: Select the main Flood Light here I assume.
Controlling Group: Group 1, 2, 3 & 4 ?
Responding Devices: Group 1 shows 001 - Indigo Z-Wave Interface, all others are blank.
Device to Add: Lists the rest of my devices.
Sat May 19, 2018 4:29 pm
Correct.
Add Node 1 to whichever groups I said.
Should be listed in the 4th box.
Sun May 20, 2018 8:38 am
Sorted - sorry to be dumb, what's the next step?
When I add a trigger using the Z-Wave Scene Controller it starts asking about 1 button press, 2 button presses etc.. ?
Sun May 20, 2018 2:10 pm
If the plugin is in Debug mode, which I think I default it to for this very reason, when you get a motion on/off from the light it should show you the relevant button commands in the log, for you to use in your trigger.
Sun May 20, 2018 2:15 pm
Sat May 26, 2018 8:04 am
Thanks Peter - just getting around to doing this today.
So I've associated the groups, and I go and walk past the light and I see nothing in the Indigo log. Am I looking in the wrong place?
Sat May 26, 2018 10:22 am
You’re on .34 and turned on plugin debug (plugins > Zwave Scene Controller > config)?
