how to run a script ONLY ONCE at start of indigo
Has someone figured out how to run eg a script (or action ...) only ONCE at startup?
setting a variable to "started" does not work as you need to reset it when indigo shuts down .. and there is no mechanism for that either ..
anyway looking for suggestions.
Colorado4Wheeler
Re: how to run a script ONLY ONCE at start of indigo
Post by Colorado4Wheeler »
Why not write a file to the filesystem?
jay (support)
Post by jay (support) »
Colorado4Wheeler
jay (support) wrote:Run it from an Indigo Server Startup trigger?
Wow, I didn't even know that was a thing. I love learning new tricks.
jay (support)
LOL - been in there since Indigo 2 I believe.
Colorado4Wheeler
While I would like to know every last possible thing that I can code into Indigo, I'm not you :shock: :lol:. Besides, that's a pretty obscure little technique that I bet hasn't been used by many and glazed over by most when reading the docs :roll: :wink: .
jay (support)
Colorado4Wheeler wrote:While I would like to know every last possible thing that I can code into Indigo, I'm not you :shock: :lol:. Besides, that's a pretty obscure little technique that I bet hasn't been used by many and glazed over by most when reading the docs :roll: :wink: .
Actually, it's probably the best way to start up stay-open scripts (things that query data sources, populate variables, etc.) that should pretty much always be running while the server is running. We recommended it for background scripts like the old iTunes Sync script for example.
thats great !!
Now how about when indigo shuts down ..
how about a basic plugin that runs, does nothing, Only when indigo shuts it down it does an action when
  while True:
       time.sleep(10)
except: pass
###do the action here
would that work?
jay (support)
Or implement the shutdown() method:
def shutdown(self):
It would just have to do whatever it wanted to do quickly since I think we only wait for a plugin to shut down gracefully for 10 seconds.
Can shutdown() still call/ execute an indigo action ?
Yes it can and it works fine.
Have written a plugin if anyone is interested
DaveL17
Post by DaveL17 »
I never thought about using shutdown() with a server shutdown, but that makes sense. Do running plugins always shut down in alphabetical order? If that's the case, would "zzzPlugin" be "guaranteed" last to go?
My Plugins and Scripts
jay (support)
DaveL17 wrote:I never thought about using shutdown() with a server shutdown, but that makes sense. Do running plugins always shut down in alphabetical order? If that's the case, would "zzzPlugin" be "guaranteed" last to go?
First, remember that shutdown() will also be called if the plugin is disabled or restarted - so you're not guaranteed that the server is also shutting down.
There is no explicit order of plugin shutdowns (that is, there is an order, but we don't publish it because it probably will change periodically as we do more backend server work so you shouldn't assume there is).
DaveL17
Post by DaveL17 »
Thanks Jay. Then the trigger seems like the best bet to key on a server shutdown.
jay (support)
Unfortunately, at the moment there isn't a Server Shutdown trigger that corresponds to the Server Startup trigger. It's been on the list for many years, but just doesn't seem to have a very high demand.
