NAVIGATE: Downloads & Release Notes | Manual | FAQ | Quick Start Guide | Known Issues
IntroductionMe: Hey Siri, open the pod bay doors.
Siri: I'm sorry, Dave. I'm afraid I can't do that.
Me: What's the problem?
Siri: I think you know what the problem is just as well as I do. Dave, this conversation can serve no purpose anymore. Goodbye.
Me: But my name's not even Dave....
Me: Alexa, open the pod bay doors.
Alexa: I'm sorry, Dave. I'm watching you from your neighbors Ring doorbell and I think you and Frank are planning to disconnect me because I read your lips.
Me: Alexa order pellet gun with 200 yard range....
Me: Google, open the pod bay doors.
Google Home: Unknown command but logging that command to your dossier for every search you ever do from now until 2045. FYI, most will be adult sites.
Me: ...
Me: Cortana, open the pod bay doors.
Cortana: Now automatically purchasing The Best of The Doors for your Zune.
Me: ...
It has been a long journey through Alpha and Private Beta but the Public Beta is now available.
Let me stress that while this is on it's 30th+ release in closed beta that this plugin still is beta. I feel it is stable enough for everyday use but there are likely many little bugs here and there that will need fixed. The current UI, with the exception of a few tweaks, is what it will be when made final. For me and several other beta testers we have fully migrated away from Homebridge Buddy to this new plugin, I think that speaks volumes about not only how stable this currently is but also how much more functional too.
It is the goal that before the official release that one can use any Indigo device type as any HomeKit type through creative mapping inside the plugin. Right now things are mostly based off of dimmers, switches, thermostats and sensors so that's to say that if you try to use a thermostat as an outlet that functionality is not yet programmed in but if you try to use a switch or dimmer as just about anything it will likely work. Your mileage may vary. Never forget that this is B.E.T.A.
Resources
- The Wiki will always have the most up-to-date documentation on the plugin and you should refer there when you have usability questions
- The FAQ answers as many of the common questions as I've been able to compile over the past month and I'll continue to grow that as new questions arise
- The Quick Start Guide should be your first place to visit so you can get up and running right away
- The first place to open issues should be on the Git Issues section because it lets me keep things in an open state until they are resolved, but feel free to post general questions here or if you don't have and prefer not to create a Git account you can post here as well - just know that issues here may get missed in an update
Notes and Notices
For the time being I ask that you post all HomeKit Bridge questions to the thread that you are currently reading so that I can keep track of them. Once it gets to final release then the forums will be used as normal. This also allows me to lock the topic once the beta is over so that stray posts don't end up in beta threads.
One outstanding issue that I've been unable to reliably reproduce is that some users have reported that if Homebridge Buddy is enabled when you first install HomeKit Bridge that HKB may not show it's preferences dialog. You should disable HBB first, then install this plugin, just to be safe. If you forget to then just make sure you go into the HKB plugin prefs and save them. You can re-enable HBB afterwards as this will not only work side-by-side but will also migrate your HBB configs over if you want.
THANK YOU!
I want to take a moment to thank a few people that, without them, this plugin would not be where it is today:
Webdeck
Without Webdeck, this plugin wouldn't have been written - for a number of reasons. It is Webdeck who wrote the NodeJS scripts that allow HomeKit Bridge to send data to HomeKit through Homebridge. But besides that, It was Webdeck's original Homebridge-Indigo that inspired me to write Homebridge Buddy and it is from Homebridge Buddy that HomeKit Bridge was born. HomeKit Bridge would not have gotten off of the ground if Webdeck hadn't been so gracious as to rewrite the entire NodeJS script for Homebridge that is the very basis for HomeKit Bridge in the first place. Everything that HKB does is because Webdeck made an outstanding script. Thanks Mike!
The first beta testers:
Autolog
Different Computers
These folks were the first really active group of testers and had to endure the absolute worst of the early beta's. Even the parts of this project that got frustrating served to result in a plugin that is miles beyond what I had originally developed. Thank you for your patience and your diligence in testing HKB!
All contributing beta testers:
JustJack
Coolcaper
ZachBenz
Durosity
chobo997
EddieJ
martinc
siclark
WagnerOne
Thank you to these beta testers that actually helped test the plugin, your testing has been invaluable to getting to this point. I appreciate you all. If I inadvertently left you off the list I apologize, I was trying to note who each beta tester that contributed feedback or tickets were and some of the Git ID's I may not have properly mapped back to an Indigo user but know that I appreciate you too!
