SecuritySpy Image Downloading and Stitching
Sat Feb 24, 2018 1:24 pm
vtmikel offline
I've created a utility plugin for SecuritySpy. I designed the plugin to ease the combined use of SecuritySpy with the Pushover plugin. SecuritySpy, even when running on the same Mac as Indigo, does not easily make available a jpg of each camera for Indigo to reference. The webcam feature only allows for FTP uploads which is not convenient.
With this plugin, you can:
  • Download individual camera snapshots from SecuritySpy, and save them to your Mac to a location you choose, driven by a variable.
  • Download multiple camera snapshots from SecuritySpy, and stitch them together vertically into a single image to a location you choose, driven by a variable
Once you do the above actions, it's easy to use the same variable to use an image in a Pushover notification. For example, if you saw motion in your camera, and you wanted to send yourself a notification with the image from that camera, this is now easy to accomplish.
I have not posted to the plugin store, yet. Available for testing here: https://github.com/mlamoure/indigo-secu ... downloader
Mike
Sat Feb 24, 2018 2:32 pm
Re: SecuritySpy Image Downloading and Stitching
You're going to need to patch your version of ghpu.py to the curl version, as the version you're using is broken now.
Sat Feb 24, 2018 5:45 pm
vtmikel offline
Will do thanks
Sun Feb 25, 2018 6:21 am
vtmikel offline
I wasn’t aware of the problems with the ghpu because I’m running HS. I’ll do the same as you and remove while we wait for a plug-in store update mechanism.
Sun Feb 25, 2018 6:42 am
I ended up patching ghpu.py with this code. Just substitute this for the original _GET function:
    def _GET(self, requestPath):
        self.logger.debug('GET %s' % requestPath)
        headers = {
            'User-Agent': 'Indigo-Plugin-Updater',
            'Accept': 'application/vnd.github.v3+json'
        data = None
        f = subprocess.Popen(["/usr/bin/curl",  'https://api.github.com'+ requestPath], stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=False)
        out, err = f.communicate()
        self.logger.debug(u'HTTP Err result: ' + unicode(err) )
        self.logger.debug(u'ReturnCode:{0}'.format(unicode(f.returncode)))
        if (int(f.returncode) == 0):
            data = json.loads(out)
            self.logger.debug(u'Json results:' + unicode(data))
        elif (400 <= f.status < 500):
            error = json.loads(out)
            self.logger.error('%s' % error['message'])
            self.logger.error('Error: %s' % unicode(err))
        return data
Sun Feb 25, 2018 1:08 pm
ZachBenz offline
Awesome! I've been wanting something just like this. Don't suppose you'd be interested in adding a third option to stitch them together into an animated GIF (and/or movie)? :-)
Tue Feb 27, 2018 3:07 pm
vtmikel offline
You may be overestimating my python skills! GIF's dont seem to be supported by pushover, which was my main reason for building the plugin. I'm not opposed if I can find a simple example to use.
Wed May 09, 2018 12:14 am
agame offline
very handy, thankyou!
Ive noticed the stitched image fails altogether if one of the Security Spy cams is unavailable.
I have a couple of flakey cams that go up and down for their own reasons.
might would be more elegant if the remaining image(s) still got stitched.
Wed May 09, 2018 3:47 pm
vtmikel offline
Thanks for the report.
Assuming I can reproduce it, I’ll get it fixed. Can you post the error you get?
Fri May 11, 2018 8:37 am
vtmikel offline
Give 1.0.2 a try and see if that resolves the problem you were having. I've made it so that if any camera isn't available, it will move on with the ones that are available.
Sat May 12, 2018 4:41 pm
agame offline
apologies was offline ... will do today/!
Sun May 13, 2018 7:24 pm
agame offline
I have tested it, and it works!
I attempted to stitch 4 cams, of which only 1 is operational - as hoped I get a single image saved in the specified directory.
I assume as intended there is an error message reported as follows (though not sure why its reporting just temp2 missing - presumably all but temp 1 would have been?):
Action Group capture and stitch gate cams
Image Downloader and SecuritySpy Helper getting image: http://xxxx/++image?cameraNum=2 and saving it to: /Users/yyyy/SecuritySpy/temp1.jpg
Image Downloader and SecuritySpy Helper Debug completed
Image Downloader and SecuritySpy Helper getting image: http://xxxx/++image?cameraNum=4 and saving it to: /Users/yyyy/SecuritySpy/temp2.jpg
Image Downloader and SecuritySpy Helper Error error getting image. Status code: 404
Image Downloader and SecuritySpy Helper Debug error obtaining image 2, skipping
Image Downloader and SecuritySpy Helper getting image: http://xxxx/++image?cameraNum=1 and saving it to: /Users/yyyy/SecuritySpy/temp3.jpg
Image Downloader and SecuritySpy Helper Debug error obtaining image 3, skipping
Image Downloader and SecuritySpy Helper getting image: http://xxxx/++image?cameraNum=3 and saving it to: /Users/yyyy/SecuritySpy/temp4.jpg
Image Downloader and SecuritySpy Helper Debug error obtaining image 4, skipping
Image Downloader and SecuritySpy Helper Error Error in plugin execution ExecuteAction:
File "plugin.py", line 178, in stitchImageAction
OSError: (2, 'No such file or directory', '/Users/yyyy/SecuritySpy/temp2.jpg')
Sun May 13, 2018 7:51 pm
vtmikel offline
Looks like I have to fix the cleanup code. It's failing trying to delete the temporary files that are created for each camera, since some of the cameras failed.
I need to revisit the event log output for this plugin, it's quite ugly. I'll put that on my list too.
Mon May 14, 2018 6:15 am
agame offline
all nice to have...but lovely that it works regardless!
Thu May 17, 2018 1:38 pm
vtmikel offline
Version 1.1 makes the fixes to the temporary file cleanup after stitching if the cameras weren't available.
Also, if you are using Cynical SecuritySpy plugin with your cameras configured, the action dialogs will now automatically load the camera numbers and names.
