HomePod not controlling HBB Devices :(
Sun Feb 11, 2018 5:26 pm
malencar offline
Hello everyone,
Just wanted to let everyone know that after receiving my two HomePods and trying to control my 50+ devices I can report that the HomePod can control all my non-HBB devices (official HomeKit devices like Hue Lights) but it says "some of your devices are not responding" to all my HBB-controlled devices.
The HBB-controlled devices all show up in the home app and can be controlled by my iPhone, Apple Watch and Apple TVs. Only the HomePod can't find them.
Is this happening to anyone else?
Cheers,
Mauro
Sun Feb 11, 2018 5:30 pm
Colorado4Wheeler offline
Re: HomePod not controlling HBB Devices :(
Works for me. There's no reason why it would work on your phone and tablet and not work on HomePod, it's all the same HomeKit database.
Sun Feb 11, 2018 5:35 pm
malencar offline
I'm befuddled then.
Everything is setup fine and, as I said, it does control my Philips Hue Lights but not the HBB ones.
Do you have any idea what could be going on?
Mauro
Sun Feb 11, 2018 5:37 pm
Also all working for me.
Sun Feb 11, 2018 5:41 pm
malencar offline
This is really weird.
I can control everything through the Home App and through Siri in all my other devices, but neither of my two new HomePods can control my HBB devices.
Any suggestions about what could be going on/what to do?
Thanks in advance
Mauro
Sun Feb 11, 2018 6:48 pm
I’m not sure what would cause that. Considering that they use the same HomeKit data and settings it doesn’t make sense. Try creating a second HBB server and adding it to see if those get recognized. Do you have multiple homes set up in HomeKit?
Sun Feb 11, 2018 7:48 pm
malencar offline
No, only one home.
I’ll try creating a second HBB later tonight to see if it works.
Mauro
Mon Feb 12, 2018 10:44 am
malencar offline
Tried the second HBB server but it didn't work.
I am at a complete loss...
Mon Feb 12, 2018 11:10 am
There's too many factors for it to be an easy solution. HBB is not in the equation in my mind because if it works in iOS then it works. I still want to think that you have a second home - or a second iCloud account with a different home setup. The reason why I think this:
  • HBB devices work but just not on your HomePod yet the HomePod uses the exact HomeKit database as every iOS device and in the same way, this makes zero sense
  • When you set up the HomePod it uses your phone to autoconfig and also asks you to log in, I noticed that when I did this I almost used my secondary iCloud account, in which case I would have not been linked up
  • If you have the Hue app on your phone then it will talk to HomeKit directly to sync up, it is possible that if you selected a different iCloud account that the Hue app linked your Hues to that HomeKit as well and that's why your Hue's work - but this is speculation
In the end several folks have stated that their HBB devices are working with HomePod so this isn't an HBB issue. As for what else to recommend I am at a loss but one thing you could try is just wiping out your entire HomeKit setup and starting over - however if a second HBB server didn't do the trick then that likely won't either. When you created the 2nd HBB server you did add it to HomeKit and you were able to test it on the iOS devices right? Do you have a 2nd iCloud account - maybe an account that is different between your "iCloud" account and your "iTunes iCloud account"?
Mon Feb 12, 2018 5:25 pm
Parp offline
Seems to be working well for me. The only minor snag for me is that Nest Home does not seem to raise the temperature when I ask it to. Probably a Nest Home plugin issue.
I LOVE the new HomePod. It sounds great!
Tue Feb 13, 2018 10:18 pm
malencar offline
I only use one iCloud account.
I don't know if this helps identify the issue but, unlike with the other iOS devices that work, when I ask the HomePod to control one of the lights nothing even appears in the log in Indigo.
Like, when I use the AppleTV remote and say "Turn off the office light" I see the following activity in the Indigo log:
Feb 13, 2018, 8:12:34 PM
WebServer request to turn on device "Office Light" from 127.0.0.1
Sent INSTEON "Office Light" on to 100
But when I do it from the HomePods nothing happens.
Any insights?
Thank you
Mauro
Tue Feb 13, 2018 10:21 pm
Not surprised as you’ve already stated it’s not working. This is a HomeKit issue then, I have no suggestions.
Fri Jun 22, 2018 9:38 am
HAupgrade offline
I have had no issues assuming the switches (lights) you’re trying to control are Insteon as that’s all I have and there’s nearly double the devices you state. That being said, you may want to look into how your HomeKit setup and Apple ID are setup. This much more likely an Apple ID syncs with iCloud issue. Just a hunch.
Users browsing this forum: Bing [Bot] and 0 guests
