No "Treat as" devices listed
Mon Jan 29, 2018 1:11 pm
stoney offline
I just got Homebridge Buddy running. Wonderful! I was never able to get the previous version to build. I've added all my relevant Indigo devices, and they show up in the iPhone "Home" app. It's rather tedious to edit them so that they have the correct rooms.
In the Homebridge Indigo Server configuration, I see all my Indigo devices in other lists, but nothing appears in any of the "Treat As..." lists. I expected all my Indigo devices to show up there. What am I missing?
Mon Jan 29, 2018 1:30 pm
Colorado4Wheeler offline
Re: No "Treat as" devices listed
It depends on how you added your devices to Homebridge. Did you use "All Devices"? Did you use Wrappers or Aliases?
The way the Treat As lists work is that if you select specific devices to add to HomeKit then those devices become available to use in "Treat As" lists. If you select all then it's just a big blanket of automatically determining (to the best of the plugins ability) the correct device type.
If you use Wrappers or Aliases then they already have a built in "Treat As" and don't need to show up on the server - in fact those devices won't show on the lists at all unless you uncheck the box in the server config to hide all Wrappers and Aliases.
It's easy to get confused on the various lists. A entirely new plugin is in the works to replace HBB in the near future that is much more straightforward in this regard.
Mon Jan 29, 2018 1:45 pm
stoney offline
Yep, that was it. When I selected "Homebridge friendly" devices from that list, they then showed up in the "Treat As..." lists. Thanks!
Thu Mar 15, 2018 5:18 pm
HAupgrade offline
Well, I’ll be darned . I actually found what I needed and don’t have to bug somebody fora change.
Thanks guys! Kudos
Love HBB!!!
