Error after Sonos Plugin 1.09 Update
Sun Mar 18, 2018 1:17 pm
wideglidejrp offline
Re: Error after Sonos Plugin 1.09 Update
Cannot imagine I would do that. I disabled plugin, renamed the one in disabled folder. Reboot iMac, restarted Indigo. Still cannot play a SiriusXM station with Indigo. Also, still getting the SoCo errors.....
Sonos SoCo Reactor Ignition...
Mar 18, 2018 at 3:15:22 PM
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 47, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 368, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 487, in socoSubTest
KeyError: (1000482231,)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
John Patrick
Author of Home Attitude
http://johnpatrick.com
Sun Mar 18, 2018 7:31 pm
nlagaros offline
Can I see all log entries from the point you start the plugin? Thanks.
Sun Mar 18, 2018 9:50 pm
koburg offline
Because this look like an error i had. Do you have HD Homerun installed ?
Mon Mar 19, 2018 8:18 am
No I do not have HD Homerun.
John Patrick
Mon Mar 19, 2018 6:00 pm
siclark offline
Normally when I get this issue, not just on sonos a restart of indigo server resolved things
Thu Mar 22, 2018 12:53 am
agame offline
I have HDHomerun installed, and my log is full of this error. Is there a known clash with HDHomerun???
Thu Mar 22, 2018 5:16 am
nlagaros offline
Can I see the logs from he point where you start the plugin. That may help identify an issue.
Thu Mar 22, 2018 4:52 pm
agame offline
sure.
Stopped plugin "Sonos 1.0.10"
Starting plugin "Sonos 1.0.10" (pid 70464)
Started plugin "Sonos 1.0.10"
Sonos Error versionCheck: Unable to reach the version server.
Sonos Debug zoneIP: 10.0.1.42, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Debug Sonos Favorites: FV:2/0, 774 ABC Melbourne | (Community), x-sonosapi-stream:s10113?sid=254&flags=8224&sn=0
Sonos Debug Sonos Favorites: FV:2/1, ABC NewsRadio 1026 (National News), x-sonosapi-stream:s7016?sid=254&flags=8224&sn=0
Sonos Debug Sonos Favorites: FV:2/7, DEEP HOUSE RADIO, x-sonosapi-stream:s224309?sid=254&flags=8224&sn=0
Sonos Debug Sonos Favorites: FV:2/2, JOY 94.9 | (LGBT), x-sonosapi-stream:s7539?sid=254&flags=8224&sn=0
Sonos Debug Sonos Favorites: FV:2/4, Koffee (Chill), x-sonosapi-stream:s108661?sid=254&flags=8224&sn=0
Sonos Debug Sonos Favorites: FV:2/5, RN - ABC Radio National, x-sonosapi-stream:s99531?sid=254&flags=8224&sn=0
Sonos Debug Sonos Favorites: FV:2/3, triple j 107.5 (Alternative Rock), x-sonosapi-stream:s89107?sid=254&flags=8224&sn=0
Sonos Loaded Sonos Favorites... [7]
Sonos Debug Playlist: SQ:3, Indigo_RINCON_5CAAFD7A4A9E01400, file:///jffs/settings/savedqueues.rsq#3
Sonos Debug Playlist: SQ:2, Indigo_RINCON_5CAAFDA7E60C01400, file:///jffs/settings/savedqueues.rsq#2
Sonos Loaded Playlists... [2]
Sonos Debug RadioTime Favorite Station: R:0/0/8, DEEP HOUSE RADIO, x-sonosapi-stream:s224309?sid=254&flags=8224&sn=0
Sonos Debug RadioTime Favorite Station: R:0/0/10, Koffee, x-sonosapi-stream:s108661?sid=254&flags=8224&sn=0
Sonos Debug RadioTime Favorite Station: R:0/0/6, RN - ABC Radio National, x-sonosapi-stream:s99531?sid=254&flags=8224&sn=0
Sonos Debug RadioTime Favorite Station: R:0/0/9, SBS Chill, x-sonosapi-stream:s126939?sid=254&flags=8224&sn=0
Sonos Loaded RadioTime Favorite Stations... [4]
Sonos Debug Sound File: doorbell-2.mp3
Sonos Loaded Sound Files... [1]
Sonos [Fri Mar 23 09:48:15 2018] Processed plugin preferences.
Sonos Serving HTTP Streamer on 10.0.1.33 [0.0.0.0], port 8889
Sonos Loaded Apple Voices.. [47]
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 284, in startup
File "./lib/twisted/internet/posixbase.py", line 382, in listenMulticast
File "./lib/twisted/internet/udp.py", line 178, in startListening
File "./lib/twisted/internet/udp.py", line 198, in _bindSocket
CannotListenError: Couldn't listen on any:1900: [Errno 48] Address already in use.
Sonos Debug ZonePlayer: SONOS PLAY:1 (portable), Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.11
Sonos Debug zoneIP: 10.0.1.11, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 10.0.1.11, RINCON_5CAAFD7A4A9E01400, SONOS PLAY:1 (portable)
Sonos Error exception in deviceStartComm(SONOS PLAY:1 (portable)): need more than 0 values to unpack
Sonos Debug ZonePlayer: SONOS PLAYBAR (Lounge), Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.42
Sonos Debug zoneIP: 10.0.1.42, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 10.0.1.42, RINCON_5CAAFDA7E60C01400, SONOS PLAYBAR (Lounge)
Sonos Error exception in deviceStartComm(SONOS PLAYBAR (Lounge)): need more than 0 values to unpack
Sonos Debug Method: runConcurrentThread
Sonos Debug Running Concurrent Thread
KeyError: (1741226548,)
any inspiration ?
Thu Mar 22, 2018 4:54 pm
nlagaros offline
Absolutely: CannotListenError: Couldn't listen on any:1900: [Errno 48] Address already in use.
You must have something else running on the machine that has locked that port.
Thu Mar 22, 2018 5:19 pm
nlagaros offline
or better yet - did you enter an IP address instead of the auto setting?
Fri Mar 23, 2018 7:13 pm
agame offline
yes, I have hard coded the IP address of the Mac running indigo. My recollection is that I did this a couple of updates ago when a previous batch of errors appeared.
I HAVE recently installed HDhomerun on that Mac.
I'm not sure how to change the default port?
Mon Mar 26, 2018 6:48 am
siclark offline
I had STP on my network for a week and 2 of the devices plugged in, and 2 on Sonos wireless but was still getting problems with log filling with connection errors, including the wired ones.
I have now moved it all over to wifi, I have 2 Unifi APs and pretty good coverage, and all seems to be ok so far.
