WallMote Quad
Sun Apr 15, 2018 4:48 pm
petematheson offline
Re: WallMote Quad
Anybody figured out how to stop it flashing every so often on its own?
Sucks as it can’t be used for bedrooms, and 3 of the ones I bought were planned for that!
Sun Apr 15, 2018 4:59 pm
Re: WallMote Quad
What’s your poll frequency set to?
If you turn it down to never, does it stop flashing?
Mon Apr 16, 2018 1:26 am
CliveS offline
Re: WallMote Quad
I have set mine to poll once per day to update the battery level (at 14.30) and no grief yet from the Boss as it is her side of the bed
CliveS
Indigo 7.2.0 : MacOS High Sierra 10.13.6 : Mac mini Server (Mid 2011) : 2 GHz Core i7. : 8 GB. : 2 x 256GB Samsung EVO SSD
Mon Apr 16, 2018 1:45 pm
Re: WallMote Quad
Ah, so simple. Seems to be working !
Fri Aug 03, 2018 5:20 am
steveoidm offline
Re: WallMote Quad
Just paired mine up but I think i'm missing something. I see the button presses coming through but how do I actually link that to an action?
Fri Aug 03, 2018 5:32 am
autolog offline
Re: WallMote Quad
Set-up a new trigger: Z-Wave Command Received > Incoming Command Received from Device and then Edit Event settings... and select from the list of different button presses. Then set-up the Action you want to perform. :)
Fri Aug 03, 2018 7:27 am
steveoidm offline
Re: WallMote Quad
Awesome, got it. Thanks!
Fri Aug 03, 2018 10:08 am
Suncroft offline
Re: WallMote Quad
I Recieved 3 of these units recently and while you can do a direct z-wave device association to dim a device I found it to be very fiddly to get an accurate dim/brightness level on the WallMote Quad due to the size of the touch area. I found a better way for me personally was to setup a trigger for single press to toggle my light on/off and then setup another trigger based on button held to use the EPS - Smart Dimmer plugin action to cycle through dim/bright for the light. Thought this may be useful for others who are looking for a way to cycle through dimming and brightening with a single hold action.
