SQL question. need help
I am trying do execute an sql statement with a column name that contains "-". e.g. xx-yy
have tried 'xx-yy' [xx-yy]
all give either an error or print string 'xx-yy' instead of the contents
any suggestions?
jay (support)
Re: SQL question. need help
Post by jay (support) »
Try back single quotes:
`column-name`
` ignores the column
tried '"[]
~:psql indigo_history -U postgres  -c  "SELECT `rx-tx-RateWiFi` from device_history_1066129470  LIMIT 10";
-bash: rx-tx-RateWiFi: command not found
(10 rows)
~:psql indigo_history -U postgres  -c  "SELECT [rx-tx-RateWiFi] from device_history_1066129470  LIMIT 10";
ERROR:  syntax error at or near "["
LINE 1: SELECT [rx-tx-RateWiFi] from device_history_1066129470  LIMI...
~:psql indigo_history -U postgres  -c  "SELECT 'rx-tx-RateWiFi' from device_history_1066129470  LIMIT 10";
    ?column?
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
 rx-tx-RateWiFi
(10 rows)
~:psql indigo_history -U postgres  -c  "SELECT \"rx-tx-RateWiFi\" from device_history_1066129470  LIMIT 10";
ERROR:  column "rx-tx-RateWiFi" does not exist
LINE 1: SELECT "rx-tx-RateWiFi" from device_history_1066129470  LIMI...
RogueProeliator
Post by RogueProeliator »
I think you want a standard double-quote around the column...
SELECT "rx-tx-RateWiFi" from device_history_1066129470 LIMIT 10
Which, of course, would require you use single quotes or elsewise escape in certain circumstances / languages.
Adam
SELECT "rx-tx-RateWiFi" from device_history_1066129470  LIMIT 10;
ERROR:  syntax error at or near "SELECT"
LINE 2: SELECT rx
indigo_history=#
nop
so ' " [ ]` does not work .. also tried to escape the "-" sign
kwijibo007
Post by kwijibo007 »
Have you tried no quote at all?
SELECT rx-tx-RateWiFi from device_history_1066129470  LIMIT 10
yes that is were I started:
 SELECT rx-tx-RateWiFi from device_history_1066129470  LIMIT 10;
ERROR:  column "rx" does not exist
LINE 1: SELECT rx-tx-RateWiFi from device_history_1066129470  LIMIT ...
.. kind of giving up.. changing the state names to _ instead of - ... tooo many problems also down the road
but still interested in how to do it
SURPRISE!!!!
Indigo replaces the - with a _ when storing the state in the database .. so replacing the - with _ in the state name has no impact on the database , all history is still there .. that was an easy change !!
RogueProeliator
FWIW, if a similar need to escape comes up in the future, it looks like double quotes is indeed the Postgre escape sequence... from the docs:
There is a second kind of identifier: the delimited identifier or quoted identifier. It is formed by enclosing an arbitrary sequence of characters in double-quotes ("). A delimited identifier is always an identifier, never a key word. So "select" could be used to refer to a column or table named "select", whereas an unquoted select would be taken as a key word and would therefore provoke a parse error when used where a table or column name is expected.
Of course, if Indigo changes your characters that won't help too much - but perhaps if you have a similar-but-not-exact issue in the future this will be here for posterity...
Adam
