Help with trigger condition
Sun May 28, 2017 10:38 am
samb offline
I need help with a trigger condition. I want a light to turn on if "varOne" or "varTwo" is true and a light sensors value is less than 50.
An alternative would be if I could set "varThree" to true if "varOne" and "varTwo" is false.
Would be really nice if someone could help me.
/Sam
Sun May 28, 2017 11:46 am
autolog offline
Re: Help with trigger condition
Hi Sam,
One way of doing this is as follows:
Set up three variables: VarOne: false, VarTwo: false and VarCheck: 0 (zero).
Then setup three triggers: One each for VarOne and VarTwo so that any change in the variable runs an Action = Variable Action (modify variable) to increment VarCheck by +1.
The third trigger will check for a change in the light sensor's value and it will also run a Variable Action (modify variable) to increment VarCheck by +1.
Then setup a fourth trigger to run whenever VarCheck has any change.
Setup a condition as follows:
Trigger Condition
Click on a + sign while holding the ALT key (the + sign changes to 3 dots) to added a compound condition as shown in the image above.
Hope this helps. :)
Sun May 28, 2017 4:05 pm
samb offline
Ok, thank you!!
I didn't know you could hold down the alt key! It solved my problem :)
/Sam
