iRoomba iRobot Plugin
Wed Dec 25, 2019 12:20 am
GlennNZ offline
Re: iRoomba iRobot Plugin
An Elf delivering a i9 would be good! -but alas not likely (they are not actually realised here yet)
The room stuff is possible, but appears a bit clunky -
https://github.com/koalazak/dorita980/issues/82
Above posted, more for my future reference.
Basically need to refer to room by its roomba ID and use a userID as well. No way of getting these, except to wait and see if appear in commands send/received and then could save room references as they appear. (which plugin could do). Would mean would need to manually send clean room command to add that room to list of rooms plugin is aware of. A bit clunky - but probably still doable.
Still, would need a local i9 really given the clunkyness I suspect.
But best of luck with your Xmas!
Glenn
Wed Dec 25, 2019 7:46 am
norcoscia offline
Happy holiday - Just FYI - the room stuff is available on the i7 as well (that is the version I got, with the external bin). If you select clean from the start page you are sent to a second page to select Clean All - or - select individual rooms from the list of rooms defined in roomba.
The vacuum does a great job and having it integrated with indigo would allow me to cycle through various rooms to vacuum whenever I'm not home. If you need any info from me to help with any efforts -- just let me know, happy to help!!!
_______
Norm
