Panasonic Viera Plugin
Mon Aug 06, 2018 5:11 am
mat offline
Re: Panasonic Viera Plugin
Colly,
Response back from Panasonic not helpful - I'll work on it when I have a few moments.
Thank you for your e-mail.
In regards to your query, I would like to inform you that the details you are looking for are regrettably not disclosed to customers by the factory.
I appreciate that this response might be disappointing and I apologise that Panasonic cannot be of assistance to you on this occasion. However, I trust that the above will help to clarify the company's position. Of course, if you should have any further queries, please do not hesitate to contact me and I will endeavour to assist.
Late 2018 mini 10.14
Mon Aug 06, 2018 2:14 pm
Colly offline
Thanks Mat,
Disappointing but not surprising..
Mon Aug 13, 2018 4:43 pm
siclark offline
Hi. Any chance that this could be sending on off toggle commands by itself or caching them?
2 hours of debugging tonight after one of my TVs randomly coming on, I have resolved all other possible issues and still a few minutes after not touching it, and with nothing edge visibly running in the log the TV comes back on by itself.
Cheers
Tue Aug 14, 2018 4:32 am
mat offline
Hi
It shouldn't be cashing anything, the commands are sent from the plugin immediately.
Before we troubleshoot, can you confirm you purchased the TV in Europe, as the power only works for "off" not "on", and wake on lan should be disabled on European models. This is an energy saving feature of the tv apparently. How old is the TV?
Are you using a plug in module to control power to the TV?
Do you also have any form of IR control of the TV? Are you using another Panasonic remote elsewhere in the house that could inadvertently be turning it on? neighbours?
If it's still acting up, please toggle debugging on and paste the green text from your event log please.
thanks
Mat
Fri Aug 17, 2018 4:57 am
siclark offline
Thanks Mat. No other Panasonic TVs and the harmony IR is no where near it. It is plugged into an HDMI matrix that can be supplying pictures to other TVs when this one is off.
I have played with some settings on the TV on the way that it is controlled by apps and network and it seems to be resolved now. The plugin works as expected, and the TV doesnt randomly come on now. I also updated the firmware and made a few other changes, so not completely convinced what the change was that worked, but all good for now.
I am sure the WOL used to work on it, but it no longer does. No idea why though.
Fri Aug 17, 2018 4:50 pm
mat offline
My understanding is the WOL is only available in certain regions. US being one and probably Asia, but its disabled in EU and AUS. The same is true of the power on, which made me suspicious it couldn't be the plugin in the EU.
Glad you got it fixed, the new firmware has Plex available if you use it, but I am still looking for the app code for it to add it to the plugin.
Any problems, please shout.
